vCORE volt mod
Most people won't need a vCORE mod since this board provides up to 2.0v and actually puts out 2.0v. The problem for me is I have a dog E8600 and it seems to run worse on this board at full boar under LN2 than the RE so I need even more vCORE. In addition to this, a vCORE mod will allow me to boot with high vCORE then tune it down when on air. High FSB requires high vCORE to boot. With the 790i Ultra one could do this with software using the NVIDIA control panel but with the 790i FTWD, this option doesn't work.
This is also a bit of a different mod as it requires two solder points on the motherboard to be combined then fed to the VR. Thanks go to Peter (Shamino) for providing the vCORE mod information. Here she be ladies...
click for full size...
http://www.3oh6.com/forum_posted/rev...ds_vcore-1.jpg http://www.3oh6.com/forum_posted/rev...ds_vcore-2.jpg http://www.3oh6.com/forum_posted/rev...ds_vcore-3.jpg
It isn't too tough of a mod but you are going to have to solder to some 0402 package resistors so a soft touch will be needed. These two solder points then get combined and connected to the VR like you normally would. The first photo shows the solder points on the board, the second photo depicts the whole area, and the last photo is a close up of my VR/jumper/read point fan header. I have been asked in the past how I set my mods up so I figured I would label the detailed photo to show exactly how it works. By removing the jumper, I am breaking the loop to ground and it is the equivalent to removing the mod.
A
10K Ω VR is perfect for this guy as at 10K Ω it bumps voltage maybe 0.04~0.05v. A 5K Ω VR might be a bit nicer for very fine control and I will likely jump over to that for benching. Your starting voltage will simply be higher.
