mine is SLAY7 3821A692
cool thanks !
i belive all 5200's are M0's also
good to know :up:
Nice budget chip! Good job.
http://shrani.si/t/37/Ks/3ZzhLSw1/e5200.jpg
I've made this screenie before i installed it...
darn mine is a PR chip
PR ? You mean ES chip? These are usually supplied for reviews, basically PR stuff....
i'd take mine out and take a pic but i don't have any TIM left
mine is SLAY7 Q826A543
I Try Q814A*** CAN DO 1.64V 5.5G
http://s9b.directupload.net/images/u...p/6uiwy6eu.jpg
donīt know if thats a good chip, but i have to add that this is a asrock conroe 1333 d667 mainboard with the intel 945gc chipset... i would like to put it in a high clockable p45 mobo :D
I guess i had no luck with this E5200. And i'm using P5Q Deluxe :rolleyes: Still it's a bit faster than E4300 and uses less power which is good since they'll increase power bills again...
i still need the 1.8 volt setting on my mobo to get 3.8
Then you're in the same league as me... it sucks doesn't it? :P
could you post a register dump from cpu-z? i canīt believe a 0.9**vid
must of got lucky myself :)
picked one up myself for benching and it does 4.0 quite eazly at 1.36250 and stable at 1,40
going to have to put it under dice soon wanna see 5.0 or better gotta love the multi :up: vid was 1.125 also leaving the mobo on auto tho and it puts 1.2 into it ran the volts up to 1.36 and bam right to 4.0 :D very picky past thier tho just getting to 4.3 was a pita .... dice time !
Man, I will have to pick one of these up.
mine was a ..3827A341 costa rica SLAY7
Ivanqu would share your settings for your run on air & on ln2 please
esp fsb & vtt & pll
E5200 on AIR. Next week im using DICE.
Vid: 1.075
SuperPi 1M:
http://img1.hugeup.com/f/11082008/9e7e43fbc065.JPG
MAX Boot:
http://img1.hugeup.com/f/11082008/5e3c11b.JPG
