Originally Posted by
JumpingJack
Both companies, Intel or AMD, when they make 'spokes person' statements related to 'expected performance increase' cloud the statement with ambiguity. For example, the 20% number AMD touts I absolutely believe in this case -- for many reasons, but my question is 20% in what? Sever based apps, perhaps just the SpecFP_Rate -- if this is what they are referring to then this 20% number will not transfer over to DT most likely because a good portion of that 20% comes from BW improvements moving to HT3 in the intersocket communications.
However, if it s 20% on average for SpecFP, SpecINT, etc. (non BW apps), then it bodes well that 15-20% is expected for DT (as the non-rate Spec benches do not press BW to it's hilt).
Frankly, we just need to wait for benchs ... if you want my personal prediction -- Shanghai will see good improvements in Server, making it much more competitive to Harpertown over a wider range of benchmarks, and extending the SpecFP_rate lead. They will also get a good power improvement from the shrink. In desktop, ~ 8-10% clock for clock improvement over Agena on average with a select few apps getting as high as 15-18% -- gaming, around 5-8% if you just measure gaming code performance ... so very 'Penryn over Conroe' like relative increases but just a bit more in this case (Penryn was on average in the 3-7% range over Conroe IPC-wise).
Total guess on my part, so those numbers should not be construed as my trying to spout facts. ... they are totally my opinion.
Jack
