Originally Posted by
mikeyakame
Just slightly above what the real vCore is, if you get 1.41v idle/load by sensors, aim for around 10mV-20mV (0.01 - 0.02v) above the actual vCore. I know the P45 boards don;'t have vTT monitoring which makes determining it a little harder but if you are using LLC I would set the vTT to around 1.38 - 1.40v max and assume a slight overvoltage due to LLC which is safe to say. Otherwise if no LLC enabled set it around 1.44v. The Rampage Formula overshoots by about 40-50mV with LLC enabled. It's safer to assume this is true when you can't monitor it via sensors. vPLL would probably want to be around 1.60-1.64V. vPLL has a very easy method to gauge whether it's right or not with Prime95. All you need to do is monitor the difference between both threads for either core and how long apart they take to complete each loop. Dual core makes it a little tougher since OS related usage can effect the accuracy, but close what you don't need running while Priming and you shouldn't get too much error in ur results from outside system resource use.
on my 65nm Q6600 G0 I use 1.4375v vCore in bios which is 1.41-1.42V real with LLC enabled under load. vTT is set to 1.42V in bios which is 1.46V real, and vPLL is set to 1.62V in bios which is 1.68V real on my board. GTLREF is set to 0.65x for CPU, and 0.63x for NB. vNB is set to 1.47v in bios which is roughly the same real. Heres a quick Everest sensor paste of mine with my voltages. Southbridge PLL = SB Sata voltage in case you don't know. CPU is running on 8x multi and 3.45GHz, FSB at 430MHz, RAM at DDR2-1149 5-5-5-15 ( 4 x 1gb sticks PSC chips I believe) and PL 7 with Phase Pull ins on A1, A3, B1, B3 to PL 6. DRAM Static Read enabled, AI Clock twister at Stronger. DRAM Voltage at 2.26 or 2.28V in bios, and DRAM Controller REF +20mV
Motherboard Name Asus Maximus Extreme / Maximus Formula / Rampage Formula
Temperatures
Motherboard 28 °C (82 °F)
CPU 21 °C (70 °F)
CPU #1 / Core #1 31 °C (88 °F)
CPU #1 / Core #2 34 °C (93 °F)
CPU #1 / Core #3 34 °C (93 °F)
CPU #1 / Core #4 38 °C (100 °F)
North Bridge 38 °C (100 °F)
South Bridge 40 °C (104 °F)
Voltage Values
CPU Core 1.42 V
+3.3 V 3.18 V
+5 V 4.94 V
+12 V 12.04 V
+5 V Standby 4.82 V
FSB VTT 1.47 V
North Bridge Core 1.49 V
South Bridge Core 1.14 V
South Bridge PLL 1.63 V
DIMM 2.30 V
DIMM VTT 1.15 V
