tremeloes, im sure your aware of the mixed metals in your system, aren't you worried?
i like the mood of your shoots especially the once you posted recently in the WC gallery
cheers
cheers
donīt forget to show me some pics when itīs finished...
what should i worry about? there are more than enough good anti corrosion fluids on the market... if someone uses only distilled water i think corrosion is his own fault.
what will you be using as a fluid? ive seen my share of corrosion with a number of different fluids.
not sure if there are any extensive tests on anti corrosive fluids and how effective they really work
but i will do a search, and im sure there really isnt alot to worry about. just something everyone questions
edit:
theres a SFF gallery thread you might want to post a few shots in there to get that thread going
http://www.xtremesystems.org/forums/...d.php?t=200986
in my v350 iīm using this:
http://www.aquatuning.de/product_inf...luid-50ml.html
in my new built i will use this one:
http://www.aquatuning.de/product_inf...quatuning.html
it is said to be the best one for laing pumps.
I used both products both for more then a half year and both sucked (not both at the same time). The first one turned my distilled water into pee. I mixed it with some blue UV stuff, so that turned out green. It didn't even help. I had lots of corrosion in my loop after 6 months.
The second one is better but still messed up my loop.
sorry, but if you mix diffrent products without knowing how they react with each other, that is not the fault of the product.
iīm using anti corro fluid in a mixed metal loop and i have no pee, corrosion or any other things.
it has a rason that on each product you can read "donīt mix it with other products". ;)
Just beautiful Tremeloes. The photography is breath-taking as always! :clap:
sorry, that sounded for me like you used anti corrosion and UV stuff together...Quote:
all i can say is that with the right mixture i never had any problems...
i changed a little. 16/10 tubes instead 13/10
http://tremeloes.kilu.de/luxxpics/_MG_3001.jpg
http://tremeloes.kilu.de/luxxpics/_MG_3005.jpg
http://tremeloes.kilu.de/luxxpics/_MG_3006.jpg
http://tremeloes.kilu.de/luxxpics/_MG_3007.jpg
nice man, looks good. will you test it and post some results when its finished?
when itīs finished i will post some...
13/10:
http://tremeloes.kilu.de/luxxpics/_MG_3012.jpg
16/10:
http://tremeloes.kilu.de/luxxpics/_MG_3018.jpg
wow this is a sick and beautiful build...subscribed!! :up:
trem.....i hate you so much...dont take offense to that btw.
your systems are incredible and one of the reason's why i want to spend a very large amount of money lol.
itīs still allive. ;)
ordered some parts today, sleeving and tv-card. hope they will arrive this week.
as compensation some pics:
http://www.abload.de/img/_mg_81619sw.jpg
http://www.abload.de/img/_mg_8154euu.jpg
http://www.abload.de/img/_mg_81584ff.jpg
figures. they just blocked abload here at work(i work on a coast guard base). ill have to check them out when i get home.
This is one hell of a sick build.
My respect on your modding and photographing, skills.
Where did you buy those white tubes(can you post a link)?
i bought them here:
http://www.a-c-shop.de/Schlaeuche-TFC
made only good experiences with a-c shop.
sick head
the inside of my NesteQ psu
http://tremeloes.kilu.de/meisterkuehler/_MG_8179.jpg
http://tremeloes.kilu.de/meisterkuehler/_MG_8180.jpg
whats ur reason for opening it up? or just cause?
