Originally Posted by
eternal_fantasy
I think my TR mosfet sinks are type1, as they were the only ones I could find when I brought them. Have had to mod the thermal pad a little longer as type 1 have a short coverage. Both the S-Max and the MCW30 will fit (NB/SB), as my NB block is also a S-Max. To be honest the SB never really gets hot, so if you can find a few ramsinks around stick them on and they will do a brilliant job. Watercooling the ICH9R is totally pointless IMO, not to mention additional block in the loop and tubing to arrange etc, or conflict with a long double slot VGA card. The S-Max does a great job on the NB, although I have ordered a MIPS nickle plated Maximus block, as IMO they are much higher quality then the EK, and better performance. Basically coolings you brought for the Maximus Formula/Extreme, Rampage formula etc will be compatible for the Rampage extreme. Kodos to ASUS for keeping the standard. :up:
Looking forward to your results. :up:
