Now there's the ticket!
The higher the power consumption the lower the variability is.
With a 600w PSU , a 4w CPU like Atom is in the noise region.We're talking a granularity yet to be found in PSUs.
JumpingJack posted a chart comparing the difference between a 600w and a 220w PSUs on an Atom system.The difference is on the order of 20w.
20 watts out of ~55 ... which is ~35% error :)
Anyway -- the reviewers are not comparing the products that are actually competing in this space. They should be looking at Nano vs the Celeron 220, in the D201GLY2A --- it is about the same performance, but the Celeron 220 consumes about 20% less power.
Jack
If you read it carefully it seems that they entire comparison is a bug. Also in your quote they're comparing the entire platform, not the CPU only. In perfomance/watt the Atom wins, in absolute perfomance the Nano wins.
Either way I still don't get WTF they've paired a 2,5W CPU with a 6W chipset. Shrink it or something :stick:
Well i think intel did silverthorn/menlow more as a proof of concept, i dont think they expected that it is such a hughe demand for it. :p
I think you will see the real performance/watt king with moorestown. :yeep:
The 8800GTX aint used for the Nano or Atom. Hothardware have been a huge failure basicly.
Also even tho some dont seem to accept it. The power consumption of the Atom is alot lower than the Nano. Even tho this is a desktop model and they still have the crappy 945 paired. It will be good to see its next incarnation.
I also think Atom is quite abit cheaper than the Nano boards. Here a Nano board cost about the same as a Q9550.
Nano´s segment is also mainly targetted as an alternative to LV/ULV "standard" mobile CPUs.
I think 55watt is to much for an Atom at full load. VR-zone managed to pull only 39,8 watts.
Anyway I'm going to test Atom power consumption myself.
Isn't there a 'Poulsbo' motherboard that works with 'Z' Atoms and uses way less power?
I'm sorry but in my book, both platforms suck. 0 performance and yet rather high power consumption.
My IBM X60 drains below 15W idle with wlan and Bluetooth enabled, and that's with a 12" screen, rather strong Yonah Dualcore and 2Gigs of ram.
Of course it costs 5x as much, but the old rule still applies I guess.. what you get is what you pay for ^^
The power drain of either Atom or nano platforms are ridiculously high in any case. Of course, hothardware's measures are incorrect as always. You won't get under 30W idle though, which is still 3x higher than it should be.
^ +1
Bang up job on all of the info and thank you very much! Yet I'll still say I'd rather have an E2180 and MATX:up:
Here's something for you to read carefully, no need for the stick since it looks like Jack explained it to both of us;)Quote:
Originally Posted by STaRGaZeR
All the reviewers should be using a PicoPSU for something like the nano or atom.....
I'm kind of amazed that in 66 posts, nobody asked how these buggers overclock? Even taking into account that they're supposed to be low power only.
Ok, that feature comparison chart, can someone please explain to me what to be concerned with there.
Ahh oh, i wasnt aware of the lower limits affecting efficiency of PSU's since i m usually only ever pushing the upper limits :P So basically the margin of error is ridiculous at that point, and it is not really a measurement of what the board is doing, but the powersupply. Gotcha.
Actually, the Centrino Atom (Atom Z + Poulsbo) is announced only to be integrated in MIDs, at the moment. The netops are more cost-oriented than power-oriented, hence the different packaging between Atom Z (lower power) and Atom N (cheaper).
We can only assume it's going to replace the current 945G+ICH7 because Intel can surely make a more profitable single bridge @ 65/45nm than sticking two 130nm bridges. At least in the long run.
And the Poulsbo may actually never come to nettops, since it has no SATA controller (it could use one PCI-e 1x lane for an external controller though).
It looks like Jumpingjack has won teh Internets :up: Someone get that man a cookie STAT! Anywho, Atom is better but the platform is f-ed, Intel needs to get a better chipset in there.
