someone willing to explain the differences between the prefetchers of AMD and Intel?
No at this point getting ATI was a good move because there gonna dominate the gpu industry thanks to price/performance.
buying ATI did cost them too much money indeed, but it was needed to buy ATI, for platfrom, CPU+GPU and all other stuff.
The loss AMD is making is basicly because of their bad CPU business, they may have lost some money on ATI, but that is no excuse for all their failures
It utterly destroyed K8 in SPi :D.Around ~17.5% faster than K8.Deneb brought us a lot more than Agena did in this particular test.
So all they needed was 3.48Ghz to break a WR that needed almost 4Ghz 65nm K10 chip to do it :D.
Being an ES still means this is not quite "tweaked" from BIOS perspective.Par this thing up with upcoming SB750 motherboard and 2 4870X2 card,what you get is all-amd-uber-system :).K10.5 is starting to look a lot like RV770 ;).
I just hope they fixed the power consumption on these procs
Everyone complains about the power consumption but considering that my opteron 165 drank almost 180W at 2.8GHz, 4 cores at 2.6GHz and 140W doesn't sound that bad :p:
OK all joking aside, yes it would be nice. I'm curious as to how much it uses and how warm it runs.
Hmm ok i see a trend here,regarding some of the comments.
AMD shows a significant improvement in a such a poor "benchmark" as SPi is,and now most people complain about TDP,even though this is C0 stepping,not the production one.
IF AMD showed zero IPC increase,even in poor SPi, BUT lower volts at those clocks we've seen,i bet most of the people that complained about TDP/power consumption would switch over to a no-IPC improvement argument.
My point is,which ever way you look at some of the comments,AMD just can't do right in some people's minds :rolleyes:
What we have here is an ES(C0 stepp.),a DVT sample back from April,that is around 12% faster in one poor synthetic benchmark(but thankfully we know that even in this one there is a great IPC increase),that clocks better than any 65nm Phenom and does this on a SB600 motherboard.All probably done on a beta BIOS and with low NB/L3 clocks.
Yeah it does look good for a beginning for sure. I am very interested to see how this all plays out.
Yes yes we know that intel does better at superpi than AMD, they always have. But superpi is not a good indication of performance between the two. The only thing it is good for IMO is getting a little bit of an idea how a CPU compares to its predecessors, in the same company. Cross company comparison is not valid. Great example is P4 vs K8, P4 was faster in superpi but lost overall compared to K8.
You think this is bad, You want to check out some of the "not happy" comments in the nehlam thread. A lot worse.
Here are a few, This one in particular is funny considering you are jizzing over AMD pi scores
Hypocrite much? Perhaps instead of wondering why people are not jumping up and down with excitement and posting only positive things about 45nm phenom you should ask yourself why you where so negative in the nehlem thread?
Maybe because Deneb was supposed to be a shrink of 65nm Phenom while Nehalem is a whole new uarchitecture?Think before posting.Yeah.Thanks.
BTW,Nehalem in MT is a beast,this is not a question.
Dont change the argument:), You got annoyed because people where not singing and dancing about these results and where questioning how they could bring any negative comment into it and I was just pointing out that every comment you made in the Intel thread was negative. Simple as that.
Change the argument?Evading much now?
The point is that Nehalem is a whole new uarch. while Deneb was supposed to be just a shrink.I never "jizzed" over SPI scores as you put it,i even said it's a lame benchmark.
BTW my comments are not negative in Nehalem thread.You are from N. Ireland,right?You speak English?Read my comments again and point where i was wrong?Boinc benchmark tool showed us some amazing score so i questioned them and said we need a real world ppd not a tool to bench HT.
Crysis was also there so i found a techarp database and looked at scores C2Qs put out,whats wrong with that??
The only really exciting score i saw was the Vantage CPU score which is really amazing.All other questions i asked were valid.And remember it was the op in the Nehalem thread(JC) that said "far from your expectations" for some of the results,not me.Is he a hypocrite?
Deneb *is* basically a shrink. Some very minor tweaks, and the larger L3 cache. It's the bigger L3 which is responsible for the sPi improvement over Phenom at the same clock. 1M sPi has an 8MB footprint, right? So now 3/4's of it fits in cache vs 1/4 on Phenom. That probably explains just about the entire speedup right there.
i am still not impressed with AMD here. the power consumption and heat with the vcore's being used is still going to be sky high. and the performance will still be behind Kentsfield clock per clock not to mention yorksfield and what lies beyond. they need an extra 20% boost to get up to competitive levels of performance clock per clock with intel and even if they got that far they still can't over clock. ohhh 500mhz overclock big whoop. my Q6600 can do a 1.5ghz overclock. so my Q6600 for $210 can do 3.9ghz on air and be faster clock per clock and this may not even hit those speeds on LN2 and will be more expensive.
i agree that it is good for them to be making progress but they are still hurting in performance.
Guys, guys, take it easy. We all know that SuperPi is Intel bench. Even in Netburst vs K7/K8 times netburst could outperform AMD in SuperPi, but in other benches/realtime applications netburst was way behind. So even with this AMD improvement in SuperPi, if we compare to equal 65nm Agena, Deneb shows major improvement. Compared to 3.6Ghz very tweaked Agena platform, Deneb is still way faster. So if AMD brings out new SB and Deneb BEFORE LGA1160 platform, they can earn some sweet bucks and get back in business. And as we know only thing that basically held back Agena OC is HTT overclocking and skyhigh power consumption and load for power phases. 45nm will solve this, so i believe 4GHz is achievable with Deneb.
Intel needs this move from AMD, we need this move, whole IT industry need this move. As fast as AMD will make very competitive product for mainstream, as fast Intel will reply with Lynnfield. And we need some healthy competition, right?
