the enzo sinks i linked to comes with a thermal sticky pad.
so you just peal and apply.
The reason why i said a nb wont work is if you use really long cards. Like HD4870X2. The block is very long, and also has a backplate! <--- that is whats gona kill you.
you can throw one of these guys on if you want then:
http://www.jab-tech.com/Cooljag-Ever...L-pr-4056.html
Max Air Flow 12.13CFM
Static Pressure 1.26mmH2O
Sound Level 22.9dB(A)
Thats more then enough for your mosfets.
just ziptie loop the corners and slip them though the fins on your alu sink.
