The FB-->GND default resistance is ~44,4k ohm !!!
I just did the Vcore mod. I used 200k VR!
Resistance changed 44,4k -> 36,5k and "def" Vcore rised
0,011V !!!
50k VR is overkill, I even wouldn't recommend 100k VR.
Use 200k or 250k VR for Vcore mod.
I used the same wire which I had already soldered for Vdroop mod:
http://ceemic.pri.ee/hardware/tpower/tpower_mod03.jpg
I just applied 200k VR to the extra PCB :)
I have switches also, so for 24/7 I don't use Vcore mod ;)
Little helping picture for moding. FB and VDIFF traces shown:
http://ceemic.pri.ee/hardware/tpower/tpower20_mod.JPG
The resistor that controls Vdroop can be "pencil moded" also, AFAIK :D
Good luck everyone!
