the smallest increment I have tried on the GPU is 5mhz and it seems to be fine...
Yup at the moment it's the only way. A bit annoying but I'm sure there will be driver based solution in the near future.
K sounds good. Just read through the other thread, glad we can atleast BIOS flash, that's more important than driver clocking to me :up:
I've uploaded my MSI bios and the modified Sapphire bios. Both are set to 710/1125MHz in 3D and 160/500MHz in 2D
http://rapidshare.com/files/12512715...-1125.rom.html
http://rapidshare.com/files/12512808...-1125.rom.html
http://img204.imageshack.us/img204/6666/7101125gq0.jpg
Be sure to backup your original bios and have a automated restore floppy/usb disk at hand, should anything go wrong. Use at own risk
Make sure you have appropiate cooling!
Very,very nice! :up:
Guys, any luck changing fan settings? RBE doesn't allow (yet), AFAIK...
900MHz, very impressive James :)
It sounds almost like we may be able to hit the limit on air cooling using the 4850. All that extra vregs on the 4870 may make it better if you are using water and above, but I imagine the 4850 has to be pretty starved for bandwidth at 900MHz core.
i know i can get more then 900 air... temps dont even hit 50c...stock clocks/volts load never broke 38c...
i stoped at 900 last night casue it was getting late. more later..
http://img110.imageshack.us/img110/667/37673207nt8.jpg
4850 Gigabyte Bios.
Maybe change this values take effect.
What effect do you suppose this to have? It will only disable overdrive for this segment inside the BIOS is protected by a checksum. Because this sum's algorithm is unknown, we can't do anything about it. You're right, the values are what overdrive offers as a maximum for overclocking using overdrive, but if they get changed, overdrive won't work at all. At least, this was the case for 3xx0 cards.
Could disabling overdrive enable rivatuner frequency adjustments by borking the driver controls on reverting clocks to the stock values? Perhaps it'll just bork the card BIOS? Worth a shot :up:
Interesting, seems the heat output on the 4850 isnt that much greater than the 3870 then. I break just over 55C @ 1GHz on 1.55v with my 3870 with my Accelero S1.
James, do you hear any "squealing" noises from the capacitors/chokes on the 4850 @ 900MHz? I had this problem with my 3870 under load such as in ATITool artifact tester
rivatuner just does not have the oc option(yet)...the little card u normally click on is not even there.
well all the way up to 875 there was no squealing. but at 900 there is a littlebit.. i have not added anything else besides some sinks.. some caps i shall be adding soon..
she is totaly 100percent stable.. played cod4(mp) for a while(an hour) at 900mhz not even a glitch... i just love how much smoother this thing is even at 700 mhz then my 3850 at 1039mhz.. :up::rolleyes::cool::p::D
now im stuck at work just wanting to play.. LOL
awesome, good to know. let us know what caps you are going to add or replace the existing ones with
have you also done the vDDR mod? I can't decide if I want to go all out with the 4850 on some good air, or drop the extra $100 for the memory bandwidth of 4870 and better power regulation circuitry. I play on 1920x1080, which is only 8% more pixels than 1600x1200
Any Chance Some one could run some benches at 750 mhz ?(other than crysis!) trying to decide on single 4870 on air or vmodded 4850 on water
Edit: would a would a 120mm rad be enough for a chipset cooler and a 4850?
THX
I can already bet that the 4870 will come out 10% ahead if not higher just from my experience with the 3850 vs 3870. Get a 4870 and clock it to 900MHz :up:
Accelero S1 rev2 on 1.51v, he mentioned it above earlier. Its a great cooler that is often overlooked, very easy to add fans that will cover the full length of the card
