When is this block supposed to hit the stores, and how much will it be?
Only $53 and supposedly next week.
The only problem is that there are plenty of 8800GTX/GTS/GT Unisinks, and none for the new generation of video cards. Otherwise, I would pounce like no tomorrow. I may stillpick up a couple to replace the aging MCW60s.
dam that looks sexy!
i really like the dtek unisink it cools my ultra mem and vregs really well.
im prolly gonna go with a 4870, i hope they come out with the red unisink :D
might ditch the mcw60... i dunno, but i like the look of this one (though you never really see it in the case :D) and that it might be able to use compression fittings.
That is one good looking block! Anyone tried it yet? I want to cool my two 8800GT's but I want to know how well this block performs first. Probably very well! =)
anyone know of any reviews of this block soon? having to hold back on buying my mcw-60 :D
You got to be kidding. The version FuZion GFX was the best performing block in the marketplace. There was no competing product. Now, this version 2 is supposedly even better. And there are Unisinks to fot your 8800GT cards. Plus, its less than $90 for block and unisink. Compared to .. what ? for a full covered ? What are you waiting for ?
Does anyone know when the new Nvidia 280 Unisink and New GPU block will be available from DTEK?:)
http://www.dtekcustoms.com/index.asp
Woo HOO !! Way to go, D-Tek !! GTX280 Unisinks !!! Hot Damn !!!
Except there still isn't a solution for the backside. OK. I need to remain optimistic !
These blocks will get some great temps.
For those that haven't bothered to follow links here's the sexyness:
http://img254.imageshack.us/img254/6...80usinkrz9.png
http://img440.imageshack.us/img440/9...isinkgtsu7.png
This is probably the finest most elegant water+air solution to date :up:
i'm getting one fo sho!
i love my ek fullcover, but i change gfx cards more often than socks :(
*wonders*
if it fits the radeon 2k, so will it fit the 4k? 4870 in particular?
(unisink also needed :worship:)
I love my silverprop cyclone fusion, but this block looks so awesome! Very tempting...
now thats smart
full block 120.00 a pop vs air block 40.00 + 52.00 = 92.00
ATI 9700 pro
X1900XT
8800 series
260/280 series
cost 40*4 = 160.00 +52 upgrade costs with air block
or 120*4 = 480.00 upgrade costs with full water block
IanY.....
I beleive the unisink is designed to be used with stock air cooler...so when you throw away the stock air cooler...only throw away the top keep the stock bottom air sink spreader and mount it to the Unisink and GPU Combo:yepp::yepp::up:
Anyone notice the C/W curve differences? I'm curious how it compares to V1 thermally...
I like GPU only blocks especially since I've epoxied on my ram sinks many moons ago...:D
Looks good except for the top. Hopefully someone is ready to sell a delrin style top.
I just hope there's a 4850/4870 Unisink
