They have a nb, they just don't have to squeeze it in between the sockets and the memory anymore.
Socket placement is loads better now :D
dual real CPU and 8x4=32 GB of Ram would be soooo sweet~~
this is the real one
http://www.zix.co.il/images/z-977168667.jpg
when are these due out?
late this year?
How do people tell the difference between 6/8/12 phase designs? I happen to like Gigabyte BTW:p:
Typically you can count the number of chokes.
Number of chokes gives you an idea of all "theoretical" phases. Gigabyte uses a simulated 12, 6 actual phase controller. Each phase of it's controller is doubled up to give you a simulated 12 phases and increased current handling capacity. You can get into the nitty gritty by figuring out what current balancing controller the board uses, most are either 4 or 8 phase.
