I can't find Cooper post :rolleyes:
This seems to be the subject of some debate... with comments from an Intel PR manager adding to the confusion just today... http://www.nehalemnews.com/2008/05/n...eaded-for.html
In the end it really doesn't provide much further clarity one way or the other.
-Chris.
Ack. I suppose they cropped the photos for the same reason they covered the socket. Tri-channel memory? I would have thought/expected three colors on the dimm slots then. Looks like 3 sticks on each of the two channels if color is any indication ... which it very well may not be.
Why 3 colours? You would use the same colour slots to populate one channel.
It IS trichannel. If it was dualchannel it would be the mainstream part and there would be only a southbridge.
http://www.hothardware.com/articleim.../big_slid5.jpg
Is the IHS the same size as the 775 IHS?
all i can say is triple channel 6x dimm slot loving baby! :D
It was a leading question. Because like HT its unidirectional. So 4.8GT/s on a 16bit link aint 19.2GB/sec. But instead its 9.6GB/sec each way. Nobody would say 100mbit ethernet is 25MB/sec per link either.
Same as people thinking they have a 6.4GB/sec/8GB/sec HT link. Instead they have 3.2 or 4GB/sec each way.
The mounting holes tell me that push pins will live on. DAMB YOU PUSH PINS!
No, the SATA2 interface supports up to 300 GB/s of bandwidth, the fastest SSD read/write speeds are just approaching 100MB/s. Samsung has also announced a drive with 200MB/s and 256GB for next year.
What I want to know, is there going to be an LGA755 version of Nehalem that will work with DDR2 boards?
55W for a mobile cpu.Isnt it too much?
I could've sworn there was either a P43 or a P53 coming out though... Either that, or I was hallucinating when I read an article... Hmm... :shrug:
wot code will lynnfield chipset/s be?
