Anyone knows if this GTX 280 will have aftermarket air cooling or it will be like the 9800GX2 that can only be cooled with water?
Does the GTX 280 CUDA client beat HD3870 CAL client by 300%, I believe it would
I want to see what CUDA would do against CTM results
And you are Charlie Demerjian? Or the oracle of delphi?
Am I the only one that thinks it would be pathetic if a dual card setup from AMD could not obliterate a single nvidia card, though, NV can release a dual card themselves, thus it is pretty irrelevant if a 4870X2 is superior.
Dunno, it seems impressive and it probably is as Dinos gave us a clear hint :D
:worship: gt280
:worship: 4xxx series.
more revenues for the 'checkout-chick' e-tailers.
Is there any confirmation which one is the fastest? GTX 280 or 4870X2?
NDA is June 17th
That's just folding and just pre marketing. Remember the old news where 2900XT was suppose to be n times faster then 8800GTX, they even got the monster specifications but the results were - how should I put it: Lame! Now, nVidia is doing the same thing - I doubt GTX 280 would be even 2x faster then HD 3870 in games, even with his 6+8 power connector... maybe 3 times the power consumption, now that I might believe.
If you can link/post a guide for doing this it would be much appreciated. According to the folding forum running a second gpu client on the second core of the 3870X2 doesn't work. See for example:
http://foldingforum.org/viewtopic.php?f=42&t=2145
the 2900 is way faster at maya and CAD and call of warez (i think that its valid its sponsored by both ATI and NV), but in gaming rendering takes a back seat to assembling frames and its not like low shader optimization and dx9 textures with dx10 shading/overlays helps ati out (dont flame, im saying NV = game, ATI = workstation)
there is a huge limit with slot bandwidth and the cpu queuing up stuff for the gpu and the client cant do it (it only will touch 1core)
I don't know if anyone has noticed, but this is a win for ATI actually.
The HD 3870 costs 3.75X Cheaper than the $600 GTX 280: http://www.newegg.com/Product/Produc...82E16814161218
So technically you get more for your card per dollar with the 3870 than you do with the GTX 280.
Perkam
Meow?
http://techreport.com/r.x/radeon-hd-3800/power-idle.gif
http://techreport.com/r.x/radeon-hd-3800/power-load.gif
That plus the price difference means Nvidia cannot claim F@H crunching superiority with this demonstration alone. Frankly I'm surprised this thread was not debunked much earlier.
Perkam
Techreport is not quite good with those figures. Here is the figures from the HD3870X2.
http://techreport.com/r.x/radeon-hd-...power-idle.gif
http://techreport.com/r.x/radeon-hd-...power-load.gif
Absolutely no consistency. Also i think he wanted you to scale AMD to the same performance. And price/performance on highend parts vs lowend parts is...not right. Its like comparing a 100$ 2.4Ghz Core 2 with a 1499$ 3.2Ghz.
