Uuuuuhhhh.... Martin, is there something wrong with the estimator? it's not like it used to be, it's all weird....
Like a list of things and thats it....:shrug:
its only the estimator, not the actual results for the block
OooooOOooH! Got it...
Hmmm, the font on some of the words like "Reservoir", "GPU", "CPU" etc, are all a little big and cut off.....
I don't know if you can tell.
Just a heads up!
Whoa, my loop runs 2GPM!!!! :shocked::shocked: Dang, thats a lot....
BTW, it's a 1c difference in temps from speed 5 to speed 1. I like running at 3, inaudible, yet It gives that extra 1c. :up:
D5 pump BTW.
Can the new block be mounted with the old mounting hardwares on 775?
Yea I don't like the TR mounting system so I wanted to use the hardware from V1 instead. At the same time I want the temp improvements hahahaa.
Situman, I was told by Danny that the old mount would work on the new block, I will verify for you later and post back. I'm with you, I think the pro mount may not be as good as everyone thinks. When I have time, (haha that's funny as :banana::banana::banana::banana: isn't it?) I hope to determine this.
Thanks a lot. If it is verified, I will need shorter screws hahahaa
