i don't think pro's and MM's runs could be considered out of order............KP's clocks are higher but the score is as well.. >> Vince stated in his 790i thread that he has not used mipmap tweak in his runs that massman asked about
http://www.xtremesystems.org/forums/...&postcount=163
i don't know if he started using it then or not but i'd be surprised considering his strong denial and also the fact it has been stated it is banned on HWBOT
nature scales with core clocks from small amount of experience i have with 8800GT >> roughly 50-60fps per 100MHz core clock jumps
SLI 8800GTS runs
pedro's core clock > 775MHz >> Nature: 1442fps
MM'c core clock > 1050MHz >> Nature: 1530fps
pro's core clock > 1080MHz >> Nature: 1538fps
KP's core clock > 1080MHz >> Nature: 1699fps
KP's GX2 core clock run > 949MHz >> Nature: 1576fps
shader clocks unknown on all those runs :confused:
i think you just need better cooling on that card pedro rather than this cheat to reach those guys :p:
