very nice work man! good job!
my first lot of rads and fans arrived today(2 x mcr320 qp rad and 6 x yate loon 33db 70cfm fans) Think I have worked out mounting for them see pics
Things have ground to a halt while trying to find some 50mm long m3.5 bolts for the rads In meantime what options is there for pc switchs I know about the bulgin switchs but $30 pre wired is a bit steep what other switchs are available for pcs and where do I find them?cheers:shrug::up:
Sweet case, keep the pics coming. :clap:
finnaly found the bolts for rads which should be here in couple days.Finished the rad mounts today will check there right once rad bolts arrive then all the sanding and painting.Will post more pics later on.:D
finally found some m3.5 bolts for rads and test fitted to mounts all sweet now can get last few things and get it painted up :clap::)
w00t! nice work, I wanna see the finished product for sure :)
does anyone know where I can get some 3pin fan connectors so I can make my own custom length cables for rads?
thanks just what I was looking for!!
just wondering I see you can buy sata connectors is it possible to make up sata power and data cables? What sort of wire is used and where to buy it?:shrug: getting closer to being able to paint have done bulk of the prep just doing final detail sanding more updates in a few days.
PPCs' AC Ryan Connectx Selection...
http://www.performance-pcs.com/catal..._id=164&page=2
nice monster case...
anybody here on extreme use the koolance quick dissconect shutt off valves.What are your experiences with them do they clog easily when pigments are used in the coolant/how much fluid leaks when dissconected etc? expecting last lot of stuff from performance pcs tomorrow then can finish off case. Then can put my money into the rest of the watercooling gear:D:up:
have not done much last couple weeks but case is sanded and I have the paint decieded to go with universal charchol hammer finish paint which I will be doing this weekend more pics coming soon!!:D
made some progress today got main part of undercoating done heres couple pics.
That window in the front should be where you put a monitor since it will be a HTPC, or if you want a monitor for watching temps etc, just a suggestion i've seen some guy put a 10.2" monitor in an NZXT Rogue........
nice!! I like thats it's wood to, more and more are going this route lately, also love these cube builds, I need to get me one of these things!
yea good idea but dont think my budget will allow for that at moment maybe further down the track.Hey has anybody used an aquarium "chiller" (basically a refrigerator unit and pump in one desiegned to chill tropical fish tanks on hot days)instead of rads and would titanium and copper mixture corrode?
brushed on good thick base coat this wil be final color but will sand back and spray top coat.Have to wait 3 days before full cure so will post pics end this week
got mobo tray done and half the case will put last paint on case tomorrow then post some more pics
nice. hope you have good weather...
Awesome work,
Wood is good, cheap and of course not expensive. You have a very nice case there. cant wait to see it finished. :D
