WOW! It looks like the 760i is the class of the Thermaltake field! :ROTF: :rofl:
http://www.legitreviews.com/article/680/7/
I had a TT - the first, my last my never again..
Again my first setup was a TT system. It didn't perform bad at all, went for a solid year without and problems.
It does not hold a candle to my current setup (With the help from you all).
If it is your first setup, great. Make the best outa it. Just keep up on the forums for what's hot and what's not.
Later when you want to upgrade (And you will), you will know your stuff.
ROFL im the only one who can get away with defending a dangerous company.
But at least i made it clear on what i was promoting and what i wasnt. :rofl:
Anyhow i figured this thread would be dead by now.
But lets ask my computer how she would feel if i added a TT watercooling product.
Heres her response flicking me off: :rofl: Man i love this pic.
http://i125.photobucket.com/albums/p...a/IMG_0949.jpg
Nae, you really do like that koolance s**t don't you.
:p, i know its selective parts, i just have to give you some crap. your not exempt. :D i agree it looks like a middle finger, but it could be made better if the barb on the left was point slightly to the left, give it that thumb feel you know.
:rofl: :ROTF: :rofl: now i get it......
Here is why i don;t like Thermaltake LCS. I just did a build in a Kandalf LCS today. I gotta say, it's a terrible RAD. The tubes are very restrictive, the block design is just silly, (and the mounting is tedious). The Pump is weak, and loud. Heck there isnt even enough flow to push bubbles around. Worst of all, this customer has SLI 8800GTX. TRY finding somewhere to mount this pump/Res. It's terrible. I eventually got it mounted in the 5.25" bays at the bottom, but it takes up about 5 of them. Terrible.
All in all, I will stick with my Swiftech/Thermochill parts. Much Much better.
and now for something completely different,,,,,,,
This is the sub for the TT setup you have, one item....
http://images.anandtech.com/galleries/20/c06.jpg
now back to your regulary scheduled boring and oh so lame TT thread.
I should have really put this......
This is CPU cooling at it's finest.....
http://www.performance-pcs.com/catal...e-plexi_01.jpg
now i got to go have a smoke.......aaahhhhhh
what air cooler is that?
i had a 735 on my secondary machine (3800x2@2.4) and while it didn't leak or fail over a period of almost 2 years i can definitely say that a TRU (not even a TRUE mind you) is quieter while cooling the same cpu to the same load temps. you WILL have to crank up the fan on your bigwater and it WILL be much louder than the TRU w/120mm fan.
Cooler Master Unveils Massive Coolers V8 and V10
http://www.anandtech.com/weblog/showpost.aspx?i=349
Mount the Rad wherever you can figure out to mount it. This is your first WC build. Have fun, if you screw it up...you're out a Birthday present, ah well.
My first WC system was a Kandalf LCS. I was nervous as hell about getting into WC because of all the horror stories I had heard.
I quickly outrew that system, rather than try to upgrades pieces...I went and built an entirely new setup.
Was a good place to start though, moving from air to WC.
Usually the directions point to the best place, and it prob can be inside or out, so it comes down to, are you a clean case kind of person....
then it's inside case, so as not to expose.
but if your an efficency person, then it's outside the case, keeps the case slightly cooler
Day187 cheers for help buddy :D :D Thank you :) :) :) top man :) :) :) and the rest of u lot too tho :D :D :D top peeps
