looks super, neat, clean BEAUTY!
Thxīs :up:
Some night picīs:
(click for bigger versions)
http://www.conman.se/rev2/natt1liten.JPG
http://www.conman.se/rev2/natt2liten.JPG
http://www.conman.se/rev2/natt3liten.JPG
http://www.conman.se/rev2/natt4liten.JPG
Great pics, thanx
click for bigger picīs :up:
http://www.conman.se/rev2/PICT2692liten.JPG
http://www.conman.se/rev2/PICT2700liten.JPG
Nice build Con!
Like that you use some "other / non standart high end stuf" like the XSPC pump :D
Some updates, mounted 3rd rad. Now 2 radīs for cpu-loop.
Orded a DDC-1T with XSPC Res-top for gpu-loop.
(click for biggerpicīs)
http://www.conman.se/rev2/dual1liten.JPG
http://www.conman.se/rev2/dual2liten.JPG
http://www.conman.se/rev2/dual3liten.JPG
http://www.conman.se/rev2/dual4liten.JPG
looks good mate very nice work
can we have your overclocking results please ?? 2 rads on cpu loop !!!!! isnt that overkill ?
24/7 setup fanīs on low-mid settings. Will remount cpu-block some day...
On high settings iīm doing 4,5Ghz, this cpu does 5,4Ghz on DI :eek:
(click for bigger)
http://www.conman.se/24setup1liten.JPG
http://www.conman.se/24setup2liten.JPG
3dmark06 link:
http://service.futuremark.com/compare?3dm06=6583357
how many pumps are you using on the CPU loop mate ?? I have the same case as you and I am considering going for a 2 loop setup rarther than a 1 on the CPU.
Did you notice much a dropp in temperture from going from 1 loop to 2 ?
Nice build mate !! Enjoy it !
Beautiful :up::yepp:
thx m8 :)
The second pump arrived today :D
More picīs tomorrow!
(click for bigger)
http://www.conman.se/rev2/2pump1liten.JPG
http://www.conman.se/rev2/2pump2liten.JPG
http://www.conman.se/rev2/2pump3liten.JPG
got to love those resi/pumps, did you start with them or slim down to them. i have 2
and they are the bomb!
love the build, that is a great case, almost got one till i saw the MM duality.
Hey conman, I have the same motherboard. How happy are you with the temps on the mosfets, NB and SB? Are any of them hot to the touch?
Was there any modification at all to get the 680i mosfet cooler to work? and the little sb fan? Can you give anymore pictures of those areas specifically (bright ones?)
thanks!
Thx m8, yes iīm happy with this build!
Thx!
No didnīt start with them, did slim down to them. They rule :up:
Real happy with the tempīs! Everything is could and running nice.
Can take some new picīs this afternoon!
No modīs for the mosfet cooler, is the top mosfet cooler that needīs mod.
Yes they are!
I turned the case upside down when i filled the loops.
So no air in my loops :up:
Will sone update to version 2.0 of my case.
Sleeving almost everything :D
Quick Question: What Feser tubing are you using? It seems to be exactly what I'm looking for, transparent blue under normal lighting and UV reactive :)
I'm assuming it's this: Feser Tube - FT - Active UV Hose - ID 3/8" - UV CLEAR / BLUE
http://www.feser-one.com/site/produc...roducts_id=293
But I just thought I'd ask for confirmation ;)
Edit: The alternative is this one: http://www.watercoolinguk.co.uk/cata...roducts_id=972
One is UV CLEAR / BLUE and the other is UV BLUE, I just would rather not end up with opaque tubes :)
Hi, this is the tube i got:
http://www.feser-one.com/site/produc...roducts_id=288
Feser Tube - FT - Active UV Hose - ID 3/8" - UV BLUE :up:
Ooo great to know :) Thanks!
Small update, Fuzion V2 and put the cover on 9800GX2
Next step is to sleev ;)
(click for bigger)
http://www.conman.se/mozart/new1liten.JPG
clean up that dom fan mate :)
I will :p:
Iīm going to take it all apart, when iīm starting to sleev everything :up:
