GSkill 2x2GB DDR2 F2-8000CL5D-4GBPQ @ 5-5-5-12
Great! Thank you. Are you running yopur GSkill 2x2GB DDR2 F2-8000CL5D-4GBPQ @ 5-5-5-12
on Auto settings?
Originally Posted by
seamumc
Just thought I'd provide my initial experience with the board so far. I've had it for a couple weeks now with a very mild overclock, just upped my multiplier by one on my QX9650 to obtain 3.3 ghz. (My specs are in my sig.)
To install on RAID properly with Vista64 SP1 I had to use the latest Intel Matrix drivers on disk at install time. Otherwise I got some real funky corruption: Shortcut's missing, incorrect icons for many shortcuts and a bunch of issues showing up in the event viewer. If you want to use Intel's RAID I strongly recommend grabbing the latest Matrix drivers and load them at install.
This is actually a much improved experience over my previous board: DFI's LanParty UT P35. I could not install using RAID or AHCI with any bios newer then 11/07. (Many folks do not have this problem, but I'm not alone with it either.)
With the mild overclock the board has been rock solid though the Vista64 boot time is signifcantly slower then with my P35. However, once booted it runs benches a teency bit faster: Disk, Memory and CPU. This is normal for DFI boards which seem to always require a bit of tweaking even at stock.
I'd have to say I'm really pleased with the board so far and I'll try to contribute more information once I start tweaking. I'm not an Xtreme type though and with 8 gigs of ram I'm going to be limited in any overclocking anyway.
Removed entire heatsink assembly!
swiftex
Do the NB/SB paste mod before using board is the easiest, just wiggle gently
If you do it after using a bit then you have to resort to the freeze etc., principles - and will risk pulling a chip ...yikes!
WHEW! I was able to remove the entire heatsink assembly.
I cleaned off both the NB and SB chips. Although I cleaned the underside of the heatsink assembly where the NB and SB meet, what I was cleaning off was some sort of rubbery (and perhaps sensitive to isopropal alcohol) uh, it looked like gray, rubbery form-fitting gue. The NB heatsink looked like it was squished onto the NB chip such that it oozed around the edges.
Am I supposed to put the AC5 grease on the chips such that it squishes against the gray rubbery form-fitting gue or am I supposed to remove the gray rubbery form-fitting gue from the underside of the heatsink? :shrug:
Above I don't mean the gray squishy pads that go against the mosfets. They look okay the way they are except you can see how some are well seated into the gray pad and others are not even touching the pads maybe.
Edro
Finally got my processor today..
3lfk1ng
Kleenex = no *rolls up newspaper, hits you on the head*
Okay. I deserved that!
3lfk1ng
Ya, I'm going to clean my NB up once I get my processor... still waiting for it *yawn*
My TRUE and Scythe S-FLEX F arrived today though :)
Just got my processor today..finally. :D That is the last piece of hardware that I've been waiting for. Plan is to build this weekend. I put all the fans in my new case already. Only regret that I didn't go with 140mm fans instead of the 120mm fans that I got. But they are great anyway.
I'll post results after the weekend. I've been reading the Areac ARC-1220 documentation. I'm real glad that I got a quality hardware RAID card. I think it is going to make a big difference for what I'm using this for. (Video encoding, media server for LAN, video editing other related video stuff)
The other thing is that I'm glad that I got a quality ASUS board. I did see the Maximus (open box) at N.E. but I decided to spring for the Rampage and I'm glad that I did.
W00t! (whatever that means!) :D
Edro
Remounting N/B, S/B on the Rampage Formula
Now that the NB and SB and heatsink assembly are all cleaned up *with a clean, lint-free cloth*, I want to put it all back on using AS5.
Should I use the credit card spread to a thin film method or the dab something like a couple grains of rice and just push it down method?
Thanks!
Edro
Rampage heatsinks, northbridge and southbridge revealed
Ah! 3lfk1ng! You beat me to it!
I just took these pics. Notice the scratches on the nb and sb heatsinks. I didn't see them until I took the flash pic. That was from using the razor blade trying to get that gray material off. It was like cemented on. Any suggestions what I should do? Lap??
The mb:
http://www.rodatus.net/openfiles/rampage/mb.jpg
Close up of nb and sb:
http://www.rodatus.net/openfiles/rampage/mbnbsb.jpg
Top side of heatsink:
The left and right half of the heatsink seem to "float" by way of some connection inside the silver part.
http://www.rodatus.net/openfiles/rampage/top.jpg
Underside of heatsink:
http://www.rodatus.net/openfiles/rampage/underside.jpg
Close up of underside of nb and sb heatsinks:
Note the scratches! They look terrible but to the naked eye you can hardly see them:
http://www.rodatus.net/openfiles/rampage/undersbnb.jpg
Edro
