I willed it to happen!
Just set it and go! LOL
Man, I'm starting to become worried now that both of my 9800GX2 GPUs aren't enabled.
http://img528.imageshack.us/img528/5282/scaredik8.png
Is this normal? And also, howdid you manage to get such rounded off overclocking frequencies? (750/1100/1900). In RivaTuner, I can never seem to be able to do this.
use "Vista/SLi friendly version" of GPU-Z
http://www.techpowerup.com/forums/sh...ad.php?t=55464
i can play Crysis @ 1680x1050 @ Very High with 30/40 fps with only one 9800Gx2 :D
>>> http://www.xtremesystems.org/forums/...d.php?t=181248
btw: for crysis (game not the bench) @ windows Vista 64bit its better 174.53 or new 174.70 (174.60 Buggy)
regards
Finally a real comparison beetwen quad sli and crossfireX...
At the actual level of parallelism 1280*1024 and 1024*768 are not resolution that can give us a real challange.
3dmark hall of fame is so similar to super pi. U don't need even dice for the gpu's.
Finally someone tested quadsli and crossfirex with a decent resolution.
Can u make a test with sli disabled? I wanna compare 3d06 and 3d05 at 1920*1200 single and sli. At this resolution the gain should be good.
A similar test with ati will be appreciated.
Like hipro said before crossfirex scales better on 4 gpu's. Even with greater resolutions and a chip with lesser power the driver support makes the difference.
Bye
I would still like to see some 01 numbers
nvidia and intel in 08-09 for the win,hands down...and only getting better...tri 9800gtx with intel 32nm nethalm should be mind blowing
@sonofander
could you give us a link where u got your drivers maybe?
i can't enable quad-sli no matter what
tried 174.53,174.60,174.70 already
XP32
thnx in advance
as i said i'm still using XP32
when i have one VGA installed i get the multi-GPU option in the NV control panel
with both cards+SLI bridge installed,the multi-GPU menu is not available at all
Quad-SLI is/will be only for Vista?cause i'd rather wait a bit than installing Vista
quad sli does need Vista OS to work.......
wow great Crysis results! Thanks for the test, can't wait to get my paws on my cards!
Happy Easter everyone!!!
doing some overclocking this morning and I got the FSB on my quad up to 500!!! :shocked:
anyway, here's a 3DM01 run for you
http://i37.photobucket.com/albums/e8...ntitled-14.jpg
I've never run 01 before, so I have no idea whether or not this is a decent score
I'll run some high res 06 tests (sli/non-sli) in a bit
One GX2 does 100k at 3dm01 ...
No doubt! Did you use bêta drivers?
@sonofander : Just to an idea as far as 3D 01 is concerned ... I score 18780 marks with a X1650 AGP and a Pentium 4 3GHz @ 3355 MHz ... :p: Hehehehehe
http://img523.imageshack.us/img523/5...18780ppcm5.jpg
ouch... I just got pwned by agp! Shame on nvidia for releasing these pieces of trash LOL
Try with only one cg you will be surprised ^^
~575 dualcore 3K06 , 2x GX2
http://www.pctunerup.com/up/results/...3_06575fsb.jpg
Has somebody had troubles with GTR Ic's and that board? (TeamGroup Xtrem-U3-1800). I use elpida modul
well guys, I guess there's no more quad sli benches from me... seems like I blew a core! :rofl:
http://i37.photobucket.com/albums/e8...ntitled-15.jpg
time to tear her down and see which card I blew
