BrowncoatGR,i raised the same question(basically) in my previous post,too.
Trying to be polite? I did not catch what you want to say :)
We are just discusing..not fighting...everyone got to be always and everywhere polite...or else we may be characterized as animals :)
We discuss to learn more and be better..right?
What do you want to say with proper? Those programs identified the cpu perfect ! This review is being generated close to 1 month, so, some programs are the latest versions from then...Quote:
there is a new version of both Sandra and Everest that added proper support for Phenom
If you look the second pic on the second page on the amd system , the cpu-z says "ganged"Quote:
Also i didnt see any mention whether you ran the tests with memory in ganged or unganged mode
The other "wrong" results on some progs seems to be bugs from the motherboard ...
Pls check here :
http://forums.amd.com/forum/messagev...threadid=91249
GoriLLakoS,what about the mentioned very low results from the Winrar that indicate the TLB fix was actually turned on(and killed the performance of 9100e even more than the singlethreaded nature of the very test did)?
Was just trying to point out that i was very carefull with the wording i used.
The problem was with the memory bandwidth not beeing reported correctly.Quote:
You are right i missed that. sorryQuote:
Dont you think that using both the TLB patch and a bios that does not work properly, makes your results unrepresentative of what a user should expect from a similar setup?Quote:
Pls check here :
From my point of view, the reviewer always writes what he saw on the specific time of the review.
1. The mobo did not recognize the cpu , and we changed the bios.
2. The TLB i think it may be visible on higher speeds and not on those speeds.
Check those results here :
http://techreport.com/r.x/phenom-tlb.../sandra-bw.gif
We got more around 7180.
3. Also take on mind that the cpu is sample and it is B2 Stepping.
Last, we run the tests as a customer would run them if he was going to purchase those setups without optimizing something.
The results are pure as we get them...if the hardware have problems, bad for them... :)
I totally agree with you that something on the AMD setup is not working properly, but if someone purchase it right now, he will face the same things.
Did you understand my point?
I am not a fanboy of intel or amd...and i am not trying to push intel.
But the results are a small sample of what is going on right now on this platforms :)
EDIT : Off course, with the time passing, most of the bugs will be fixed, but this is the image we have in our mind for the time being.
Do you agree with this?
9100e looks nice and with TLB errata fix disabled will make good entry level workstation.
I assumed that this was the case. My point is that this makes your results totally unrepresentative in regard to every other motherboard a user could use. In essence you compred a properly functioning system with a system that was performing below its capabilities.
I meant the bios fix not the bug itself, but i does look like it might not enabled and its just the mobo acting up. I think though techreport was using the version that wasnt reporting mem bandwidth correctly.Quote:
Yes and it seems all new chips hve appeared as b3 versions only at least here in Greece(even all the tricores are B3). Which is why i think the results you posted are not representative of the capability of the cpu and what most users will experience using the cpu. That obviously doesnt mean that the e4700 isnt a better cpu for all single threaded and lightly threaded apps.Quote:
Yes i understand your point but it seems to be a problem isolated to the motherboard being used. Additionally it is a bios issue that is going to be worked out in a few weeks. As such any reader not aware of ths will make wrongfull conclusions. At the very least you should mention that the processor was not working at its full potential because of problems with the motherboard. It is also quiteclear tht AMDs platform still has teething problems and that should also be mentioned in the cons.Quote:
Thanks for the review.
Do you still have the 9100e?
If so, could you run some tests (preferably games and some winrar etc) with the tlb patch disabled?
We almost agree on most of the performance feedback...i will try to re-run every benchmark when the final B3 will come out , i will re-check to see what the heck is going on :)
Regarding TLB, there was TLB on all the progs, but there is no a bios setting to disable it..only a (semi)hide button on AMD overdrive to click on it and disable it in win...
Voudas(the guy that made the review) will re-run all the progs with no TLB and add the results(but it may take some time :) )
So, we are looking forward for the B3s and new results...:)
Great! :up:
can you Oc the phenom to 2.6ghz and rerun de 3dmark benchs?
The Phenom is actually a very nice CPU guys you should try it you may even agree:) Mine is at 2800mhz @1.23vcore Stable!
More than likely, NO! Common thinking is that if they had Headroom, AMD would have sold them as higher end models. This is similar to the *most 3500 and 3800 Dual Cores. Now, extreme and voltage might let it overclock some but I'd be surprised to see more than 1.9 to 2.1GHz over volted and etc....
Yet, it'd still make a great Home Server processor or etc.... I can see these sell in that quickly growing Home Server market.
http://seekingalpha.com/article/2370...-server-market
http://www.physorg.com/news98621889.html
http://www.windowsfordevices.com/news/NS6378793892.html
Be that home server Linux or MS, I've seen more of them as I visit folks. Even folks with multiple laptops showed off that old Destop now setup as a File/Home Server. Here, this 1.8GHz QC would make a great fit:) Or is that bashing AMD?:rolleyes:
I think it could just OC quiet nice, since its a 65w model, but i guess i have to buy one and test it.:up:
I just saw 9500's are available for 110euro's.. wonder what these babys are gonna cost :shocked:
@GoriLLakoS
Thank you for the very good review. :toast:
It would be nice if you can find and add an E7200 and a Phenom 8400 to the charts. Both are in the same price range as the Phenom 9100. Also you should have tried OC-ing. Most of us here are interested about the CPU OC-ed. And of course if you can translate in English the entire review it would be very appreciated and helpful for many people around the world.
Anyway if I can find it around for 100 euros I'll buy one for experimenting. I hope it'll be stable OC-ed to 2.4GHz cores/2GHz NB&L3 and as such I guess it'll be an upgrade of my 2.8GHz OC-ed Brisbane.
Graphs with TLB off is up and running
http://www.hwbox.gr/showthread.php?t=1219&garpg=4
http://www.hwbox.gr/showthread.php?t=1219&garpg=5
http://www.hwbox.gr/showthread.php?t=1219&garpg=6
http://www.hwbox.gr/showthread.php?t=1219&garpg=7
http://www.hwbox.gr/showthread.php?t=1219&garpg=8
http://www.hwbox.gr/showthread.php?t=1219&garpg=9
http://www.hwbox.gr/showthread.php?t=1219&garpg=10
http://www.hwbox.gr/showthread.php?t=1219&garpg=11
Seems like no big difference...
