Originally Posted by
Synthetickiller
Thanks a TON. I'm trying to collect some info for when I build a nehalem based system in the not so near future. I would probably get a tank about the same size as yours.
My idea is that if I can eliminate some heat entering the tank, clearly, the chiller's effect will last longer since it would be on an OC'd processor, NB and video card most likely in a single loop.
I know that I can't drop the temps below ambient, but pumping in water that is 10 or more degrees below a loop w/o a rad, that would be worth it and might take a a small portion of the workload off the chiller.
At least I think so.....
