You will need to increase what rivatuner allows at the maximum clock in the power user section... cant remember exactly what it is off the top of my head.
Thank you STEvil for your help , ill try messing around with rivatuner. appreciate your response.
chispy.
In the Power User tab go to Riva Tuner \ Overclocking \ Global and edit the value for "MaxClockLimit" to 150 or 200 or something... higher the value the higher your overclocking limit.
anyone can help me ?
http://www.xtremesystems.org/forums/...d.php?t=208032
Hi! have a MSI Geforce 8400gs which i would like to voltmod. It has the APW7067 IC. Will this mod also work for my card(the PCB is different)?
^ Not too likely. Start a new thread with pics an stuff an I'm sure theres plenty of folk who can help ya ;)
I bought an EVGA 8400GS a few days ago and I want to volt mod it. The IC layout is a little bit different than the Asus 8400GS. Here are some high res pictures of the PCB. Can someone help me find out if a pencil mod is possible with this card? Thanks in advance.
Whole card
http://bayimg.com/image/cafbaaacc.jpg
Top left
http://bayimg.com/image/cafbdaacc.jpg
Top right
http://bayimg.com/image/cafbgaacc.jpg
I was kinda bumbed after I found out my card is the crippled G98 8 shader version instead of the decent G86 16 shader version. I hate Nvidia for these schemes.
I got help on another forum on the pencil mod. I shaded the resistor from 770ohms down to 560 ohms. After the mod the blue leg reads 1.390v. Right now I'm running at 910 core, 2125 shaders, 400 mem. (This is with a modded old CPU cooler) Haven't messed with the mem yet. But I don't think I'll do the vmem mod, since the mem chips don't have a heatsink on them.
http://bayimg.com/image/pafnoaacj.jpg
Do this at your own risk.
Question, my resistor is in the same spot as STEvil but is has a different number (it's not 44B), is this a problem or can I remove it to have OCP removed?
Edit:
Ok here's a pic of mine, as you can see my chip is not marked as 44b like on Stevil's card, it's marked as 53b. They are exactly the same card can I remove that chip to do the OCP mod?
http://img11.imageshack.us/img11/1696/img0320ub.th.jpg
^^^Bump added picture.
:up:
you could also pencil it down
guys, how do i reduce vGPU or is this offtopic :)
Do i put VR in place of orange resistor?
http://www.xtremesystems.org/forums/...1&d=1202573572
