Ok, so the key word is OPTIMIZED. There are plenty of games that USE a quad, just not OPTIMALLY. :)
Overclocked the 3870x2 to 860/1050 not too big a difference but broke 34fps LOL
2/19/2008 5:42:42 PM - Vista 64
Beginning Run #1 on Map-sphere, Demo-autotest
DX10 1024x768, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Demo Loops=3, Time Of Day= 9
Global Game Quality: VeryHigh
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 82.89s)
!TimeDemo Run 0 Finished.
Play Time: 62.12s, Average FPS: 32.19
Min FPS: 18.35 at frame 117, Max FPS: 44.16 at frame 793
Average Tri/Sec: -25776754, Tri/Frame: -800657
Recorded/Played Tris ratio: 0.82
!TimeDemo Run 1 Finished.
Play Time: 58.48s, Average FPS: 34.20
Min FPS: 18.35 at frame 117, Max FPS: 44.68 at frame 787
Average Tri/Sec: -27429248, Tri/Frame: -802037
!TimeDemo Run 2 Finished.
Play Time: 58.49s, Average FPS: 34.19
Min FPS: 18.35 at frame 117, Max FPS: 45.75 at frame 810
Average Tri/Sec: -27425436, Tri/Frame: -802045
TimeDemo Play Ended, (3 Runs Performed)
Completed All Tests
<><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><>
Run #1- DX10 1024x768 AA=No AA, 32 bit test, Quality: VeryHigh ~~ Overall Average FPS: 34.195
Dual-core 939@ 3.0GHz & 8800GTS 320MB 670/1000
:P
20/02/2008 18:35:59 - XP
Beginning Run #1 on Map-sphere, Demo-sphere
DX9 1024x768, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Global Game Quality: High
Play Time: 52.99s, Average FPS: 37.74
Min FPS: 8.75 at frame 1761, Max FPS: 61.04 at frame 767
Average Tri/Sec: 34966164, Tri/Frame: 926408
Recorded/Played Tris ratio: -0.71
Play Time: 47.07s, Average FPS: 42.49
Min FPS: 8.75 at frame 1761, Max FPS: 64.50 at frame 785
Average Tri/Sec: 39432648, Tri/Frame: 928051
Play Time: 47.12s, Average FPS: 42.45
Average Tri/Sec: 39398344, Tri/Frame: 928135
Completed All Tests
Run #1- DX9 1024x768 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 42.47
Map-harbor, Demo-Assault_Harbor
Run #1- DX9 1280x1024 AA=2x, 32 bit test, Quality: High ~~ Last Average FPS: 17.07
Run #2- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Last Average FPS: 24.91
Run #3- DX9 1280x1024 AA=No AA, 32 bit test, Quality: Medium ~~ Last Average FPS: 34.93
Run #4- DX9 1280x1024 AA=2x, 32 bit test, Quality: Medium ~~ Last Average FPS: 26.60
Run #5- DX9 1280x1024 AA=4x, 32 bit test, Quality: Medium ~~ Last Average FPS: 17.80
it crashes when you open or when you try to run a timedemo?
do you have v1.1 and it works normally? only other thing i can think of is a messed up Crysis.exe (possibly the x32 .exe in 64bit folder?)
you could try to reinstall. maybe copy My Games/Crysis folder, reinstall and patch then put old Crysis folder back so you still have your config files.
It doesnt open period. When I click on the icon for that app, it gives an application error.
I will try reinstalling it though.
Crysis works fine itself so it couldnt be the crysis.exe.
as long as you have both files try running in admin mode or compatibility, maybe re-extract from the zip file since they may be corrupted.
any hotfixes or sp's could play foul as well. vista x64 rc2 works, which is what i use
It doesnt work in Vista32 or Xp32.
Thanks, I will report back. :)
bluehaze could you be so kind and run your CPU and GPU in default frequencies with this settings with "benchmark_cpu2" timedemo ("ice" level)
http://img340.imageshack.us/img340/8...ysispx3.th.jpg
thank you!!
:wave:
meh...
Q6600 (stock) - HD3870x2 (stock) - 2GB ram at 1333mhz - Installed on new 150GB Raptor.
3/8/2008 12:14:33 PM - Vista
Beginning Run #1 on Map-island, Demo-benchmark_gpu
DX10 1680x1050, AA=No AA, Vsync=Disabled, 32 bit test, Windowed
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
Play Time: 239.04s, Average FPS: 8.37
Min FPS: 0.00 at frame 1796, Max FPS: 13.20 at frame 975
Average Tri/Sec: -3330879, Tri/Frame: -398102
Recorded/Played Tris ratio: -2.30
Completed All Tests
3/8/2008 12:30:16 PM - Vista
Beginning Run #1 on Map-island, Demo-benchmark_cpu
DX10 1280x1024, AA=No AA, Vsync=Disabled, 32 bit test, Windowed
TimeDemo Play Started , (Total Frames: 1500, Recorded Time: 44.62s)
Play Time: 84.42s, Average FPS: 17.77
Min FPS: 4.13 at frame 809, Max FPS: 27.84 at frame 124
Average Tri/Sec: 22629432, Tri/Frame: 1273644
Recorded/Played Tris ratio: 0.56
Play Time: 68.78s, Average FPS: 21.81
Min FPS: 4.13 at frame 809, Max FPS: 29.33 at frame 107
Average Tri/Sec: 27826900, Tri/Frame: 1275966
Play Time: 65.15s, Average FPS: 23.03
Min FPS: 4.13 at frame 809, Max FPS: 30.99 at frame 367
Average Tri/Sec: 29381034, Tri/Frame: 1276030
Completed All Tests
Run #1- DX10 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 22.42
Any ideas why its so crappy? :S
My current psu doesn't have a 8pin PCIE connector, so i have 2 6pins connected as the manual said to do.
1024x768
http://img245.imageshack.us/img245/3...highkd4.th.jpg
1680x1050
http://img516.imageshack.us/img516/1...highjp4.th.jpg
q6600@3.6ghz,
hd3870 crossfire @ 805/1201
CAT 8.3
I would love too, unfortunately my 3870x2 died so I am unable to bench with it anymore :( It was a great card but I have since moved on to 8800GTX SLi on an EVGA 780i :D
Sapphire really pissed me off LOL worst support ever, they wouldn't give me an RMA told me to deal with the vendor since it was under 30 days. Thankfully though the vendor (FXVideocards.com) was very kind and actually refunded me the money for the card even though the return policy said no refunds and I believe was only 14 days return policy. Really great store with good prices and I will shop with them from now on however Sapphire left such a bad taste in the way they chose to handle this that I doubt I will ever buy another ATI card again. I mean the card was not even released 30 days prior to dying and Sapphire is already giving me the runaround? Good riddens Sapphire, Hello EVGA!
Will post some benches in a couple minutes with the new setup!
Cheers!
Q6600@3.6ghz, EVGA 780i, 8800GTX SLi
1024x768 Very High 50FPS
http://i180.photobucket.com/albums/x...phere50025.jpg
1680x1050 Very High 31FPS
http://i180.photobucket.com/albums/x...sphere3108.jpg
C2D 6850 @ 3.6GHz
eVGA 680i 122-CK-NF68
4x1Gb , 480MHz @ 4-4-4-10-2T
Windows Vista Ultimate 64 , FW 174.74 Beta
8800GTX in SLI @ 612/1512/1000
2560x1600
http://img167.imageshack.us/img167/4425/6013um2.jpg
http://img167.imageshack.us/img167/4839/2887qb9.jpg
http://img248.imageshack.us/img248/9556/1491mo2.jpg
http://img519.imageshack.us/img519/9007/1072qd1.jpg
__________________________________________________ ______________________________________________
1900x1200
http://img212.imageshack.us/img212/7812/6503wl5.jpg
http://img212.imageshack.us/img212/2904/4956ks7.jpg
http://img248.imageshack.us/img248/6388/4165ym2.jpg
http://img248.imageshack.us/img248/1671/2709rg7.jpg
1680x1050
http://img210.imageshack.us/img210/2064/4842fb8.jpg
http://img262.imageshack.us/img262/7127/3273ha2.jpg
how about 1680 x 1050 2xaa very high? and high please.
I also have gtx sli but pc is not up yet
:yepp:
8800GTX Tri SLI numbers coming later this week after i get my Tri SLI Bridge :D
http://img523.imageshack.us/img523/2502/4136xo6.jpg
http://img186.imageshack.us/img186/1461/2577ge8.jpg
4/13/2008 4:23:30 AM - XP
Demo Loops=1, Time Of Day= 9
Play Time: 39.35s, Average FPS: 50.83
Min FPS: 33.96 at frame 1772, Max FPS: 75.66 at frame 793
Average Tri/Sec: 47103656, Tri/Frame: 926656
TimeDemo Play Ended, (1 Runs Performed)
Completed All Tests
Run #1- DX9 1024x768 AA=No AA, 32 bit test, Quality: High ~~ Last Average FPS: 50.83
Setup:E8400@4014mhz,Crucial Ballistix Tracer@DDR 2 892,4-4-4-8,8800GT@720core/1782shader/975mem,forcerware 174.74 beta.
4/13/2008 4:33:02 AM - XP
Play Time: 40.12s, Average FPS: 49.85
Min FPS: 15.76 at frame 1762, Max FPS: 71.74 at frame 837
Average Tri/Sec: 46191536, Tri/Frame: 926667
Play Time: 37.11s, Average FPS: 53.89
Min FPS: 15.76 at frame 1762, Max FPS: 75.28 at frame 826
Average Tri/Sec: 50021352, Tri/Frame: 928196
Play Time: 37.08s, Average FPS: 53.93
Min FPS: 15.76 at frame 1762, Max FPS: 75.94 at frame 818
Average Tri/Sec: 50063976, Tri/Frame: 928240
Completed All Tests
Run #1- DX9 1024x768 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 53.91
Sorry,forget to copy the log of 1440x900 but have ss.
SS:
1024x768:http://farm4.static.flickr.com/3089/...565ae084_b.jpg
1440x900:http://farm3.static.flickr.com/2106/...c1b2cc90_b.jpg
Ran some benchies on my second rig
Pretty impressed by what these 8800gs's have to offer for less then 90euro's:up:
13-4-2008 0:28:33 - Vista 64
Play Time: 54.14s, Average FPS: 36.94
Min FPS: 15.42 at frame 490, Max FPS: 60.82 at frame 772
Average Tri/Sec: 33418376, Tri/Frame: 904632
Recorded/Played Tris ratio: -0.73
Play Time: 46.17s, Average FPS: 43.32
Min FPS: 15.42 at frame 490, Max FPS: 61.61 at frame 810
Average Tri/Sec: 39279784, Tri/Frame: 906695
Play Time: 46.03s, Average FPS: 43.45
Min FPS: 15.42 at frame 490, Max FPS: 61.69 at frame 813
Average Tri/Sec: 39398396, Tri/Frame: 906840
Completed All Tests
Run #1- DX9 1024x768 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 4338,5
Here's my log from 2x 9600gt sli and q6600@3600 with MSI 780i, settings high, no AA, 1600x1200 and 1280x1024, DX9 scores with xp64
DX9 1600x1200, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Play Time: 57.74s, Average FPS: 34.64
Min FPS: 21.54 at frame 138, Max FPS: 47.57 at frame 974
Average Tri/Sec: -30172962, Tri/Frame: -871059
Recorded/Played Tris ratio: -1.05
Play Time: 49.12s, Average FPS: 40.72
Min FPS: 21.54 at frame 138, Max FPS: 48.72 at frame 68
Average Tri/Sec: -35413484, Tri/Frame: -869765
Play Time: 48.76s, Average FPS: 41.01
Min FPS: 21.54 at frame 138, Max FPS: 49.56 at frame 991
Average Tri/Sec: -35598688, Tri/Frame: -867976
Recorded/Played Tris ratio: -1.06
Beginning Run #2 on Map-island, Demo-benchmark_gpu
DX9 1280x1024, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Play Time: 47.37s, Average FPS: 42.22
Min FPS: 24.82 at frame 162, Max FPS: 60.31 at frame 1010
Average Tri/Sec: -40091084, Tri/Frame: -949639
Recorded/Played Tris ratio: -0.97
Play Time: 39.82s, Average FPS: 50.23
Min FPS: 24.82 at frame 162, Max FPS: 63.97 at frame 98
Average Tri/Sec: -47663036, Tri/Frame: -948945
Play Time: 38.55s, Average FPS: 51.88
Min FPS: 24.82 at frame 162, Max FPS: 64.33 at frame 1014
Average Tri/Sec: -49173612, Tri/Frame: -947783
Completed All Tests
3/29/2008 11:20:19 PM -
Run #1- DX9 1600x1200 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 40.865
Run #2- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 51.055
My GT@720core/1782shader/975mem,E8400@4014mhz:
Play Time: 50.29s, Average FPS: 39.77
Min FPS: 9.94 at frame 143, Max FPS: 51.59 at frame 1016
Average Tri/Sec: 39855064, Tri/Frame: 1002108
Recorded/Played Tris ratio: 0.91
Play Time: 44.74s, Average FPS: 44.70
Min FPS: 9.94 at frame 143, Max FPS: 54.25 at frame 1001
Average Tri/Sec: 45357584, Tri/Frame: 1014655
Recorded/Played Tris ratio: 0.90
Play Time: 44.71s, Average FPS: 44.74
Average Tri/Sec: 45397084, Tri/Frame: 1014778
Completed All Tests
4/14/2008 8:13:23 PM - XP
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 44.72
DX9 1400x960, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Play Time: 47.74s, Average FPS: 41.89
Min FPS: 33.17 at frame 1964, Max FPS: 50.89 at frame 989
Average Tri/Sec: -42271644, Tri/Frame: -1009099
Recorded/Played Tris ratio: -0.91
Play Time: 45.86s, Average FPS: 43.61
Min FPS: 33.17 at frame 1964, Max FPS: 51.84 at frame 1018
Average Tri/Sec: -43472848, Tri/Frame: -996891
Recorded/Played Tris ratio: -0.92
Min FPS: 33.15 at frame 1964, Max FPS: 51.84 at frame 1018
Average Tri/Sec: -43440764, Tri/Frame: -996148
Completed All Tests
4/14/2008 8:18:59 PM - XP
Run #1- DX9 1400x960 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 43.61
