Savegames are working perfectly for me.
Uhhhhhh, any actual benchmark comparisons???
You can just delete the movie files. No need to crack it to stop the intros from playing.
Cool!
I'm getting smooth play @ 1920 x 1200 4xAA with my Q6600 @ default speeds *happy dance* :)
Yeah and also the "medium" setting :P
I can run All high, textures very high from 15-25 fps. So when I run it normally on a medium/high mix it's really smooth now.
I only seem to get 1-2 fps extra with this patch. I too use the no-dvd crack and can still use all my saves. All I had to to was install the patch and copy the cracked exe back.
Yay
Is this going to fix the nvidia driver stopped working but recovered bullshyt?? I cant even fuking play the game untill this shyt is fixed. Doesn't look like Ill be able to use my X-Fi either untill Nvidia and Creative get off there fuking asses and do something about that crackling/ripping and no sound crap.
Wow, 2 pages of banter and not a single comparison benchmark. :clap:
trust me i dont know about what everyone else says about the game tweeks but it sux!!! missles now tooo slow...granades dont kill ppl...it bites...im going back to the normal game without the patch
you need to make sure your movies are named properly. I had to rename them to fix the bullshid
HOT DAMN:D Actually just bought the game the other day when I bought my 2 POWERCOLOR HD 3870 got them today and eggy says the 10th for Crysis:cool: now I get to check out the game without hindrance:clap:
First = Vista64, Cat 7.11 (forgot to bench with the 7.12s, sorry), 1920x1080, all med settings, no AA, v1.0
Second = same everything but v1.1
Third = same everything but v1.1 and r_multigpu = 0 (didn't check for issues with shadows, which flickered in v1.0 with r_multigpu = 0).
So ~2-3 fps increase.
Just make sure the drive is using the same letter you used on the install, otherwise it freaks out.
Here's a repost of my Crossfire results:
EDIT: This is the CPU Benchmark, not the GPU.
Here's my cfg:Quote:
Crossfire is working in DX10, which is a huge boost that actually makes DX10 usable.
Now I'm waiting for the patch that adds fun to the game.
DX10 3870, single card, 1680x1050, custom cfg file, rig in my sig:
DX10 3870 Crossfire enabled:Code:==============================================================
TimeDemo Play Started , (Total Frames: 1500, Recorded Time: 44.62s)
!TimeDemo Run 0 Finished.
Play Time: 52.06s, Average FPS: 28.81
Min FPS: 8.90 at frame 199, Max FPS: 42.49 at frame 119
Average Tri/Sec: 25240396, Tri/Frame: 875956
Recorded/Played Tris ratio: 0.82
!TimeDemo Run 1 Finished.
Play Time: 47.46s, Average FPS: 31.61
Average Tri/Sec: 27811818, Tri/Frame: 879892
!TimeDemo Run 2 Finished.
Play Time: 47.39s, Average FPS: 31.65
Average Tri/Sec: 27835384, Tri/Frame: 879347
!TimeDemo Run 3 Finished.
Play Time: 46.99s, Average FPS: 31.92
Average Tri/Sec: 28013810, Tri/Frame: 877569
TimeDemo Play Ended, (4 Runs Performed)
Play Time: 41.34s, Average FPS: 36.28
Min FPS: 17.15 at frame 196, Max FPS: 57.20 at frame 358
Average Tri/Sec: 34260396, Tri/Frame: 944279
Recorded/Played Tris ratio: 0.76
Play Time: 34.70s, Average FPS: 43.23
Average Tri/Sec: 40983672, Tri/Frame: 948042
Play Time: 34.39s, Average FPS: 43.62
Average Tri/Sec: 41279668, Tri/Frame: 946418
Play Time: 34.34s, Average FPS: 43.68
Average Tri/Sec: 41630512, Tri/Frame: 953078
Recorded/Played Tris ratio: 0.75
Code:con_restricted=0
r_displayinfo=1
sys_preload = 1
r_VSync=0
d3d9_TripleBuffering=0
r_ssao_quality=1
r_ssao_amount=1
r_SSAO_darkening=0.7
r_TerrainAO_FadeDist=1
r_HDRlevel=0.75
r_TexturesStreaming=0
r_ColorGradingDOF=0
r_ShadowJittering=1
r_ShadowBlur=0
e_gsm_lods_num=4
e_shadows_from_terrain_in_all_lods=0
r_UseEdgeAA=0
r_depthoffield = 1
e_shadows_max_texture_size=256
e_view_dist_ratio=45
e_particles_lod=0.7
e_vegetation_min_size=1.5
e_view_dist_ratio_vegetation=50
r_SSAO_radius=1
r_sunshafts=1
r_Beams = 3
r_BeamsMaxSlices=100
e_particles_thread = 1
g_blood = 1
q_ShaderShadow=1
r_EyeAdaptationBase=0.2
e_vegetation_sprites_distance_ratio = .7
e_lod_ratio = 4
e_detail_materials_view_dist_xy = 1024
e_terrain_texture_lod_ratio = 1.5
e_terrain_lod_ratio = 1.5
e_view_dist_ratio_vegetation=20 ;20 for performance
r_TexturesStreaming = 0
