you never know. im waiting on funding confirmation to start my PhD at wollongong university, but if that falls through i could be doing anything - i'll need full time work so i'll take whatever suits me best wherever that may be :)
good luck with ur schooling :up:
Am looking for a dewar any chance ur schools department have a got something they r about to throw out?
Finding it hard to find 1 :(
Awesome, but remember common sense when buying a used one:
1. Best to pressure test it first to check for air leaks (otherwise, if it leaks, you could die.............generally thought of as a bad thing). You losing that little probably means you're fine.
2. Best to use it in a well ventilated area (ie. tunnel of air in and out)
3. Be extremely careful handling the ln2. Burns = teh bad. Protection over exposed skin and eyes recommended.
4. Use it enough to smash every record you can ;)
I highly doubt dinos22 needs to be reminded of this, but it's good info for anyone looking to get into this.
yeah i was aware but you are right it's good to always remind people
also if you are benching on tiles wear some SHOES hahahah :D (no joke) heh
i have a dungeon i bench in and leave the front door open and have a pedestal fan behind me hammering the room to get some air circulating and pushing out of the room
i did have some reservations but i think it should be fine
burns under the toes are not nice :(
