He must have a huge vdrop cuz more than 1.55 should run pretty hot.
Is under 70, Yes the vdrop is about 0´5 from 1.55 in bios to 1.5 - 1.49 In windows
1.325 vid = 3.6ghz at 1.50vcore on 4 phase digital power, Under water max, speedstep and thermal control and vdroop enabled
I'm under Tt bigwater 745 with fans slowed down to 7v.
it drops to 1.4xx, I think 1.470's I can't remember exactly, I kinda gave up totally as soon as I found out it won't be stable on anything more than 3.43
I'm still on P5K SE, which I believe is 3 phase power.
Just check my post on page 1. Have pictures attached.
I've got my L738B555 12/20/07 at 3.6 with a vcore of 1.47. VID is 1.325.
I think I got the lowest VID for L804 batch :D
Mine has 1.285 VID and it runs stable @3.4 with 1.425v in Bios (1.36 CPU-Z) and all this with Stock Intel HSF :ROTF:
It is hell hot here in Egypt :(
I see i,m giving it 1.44 in bios, maybe i should try 1.47. :confused:
Horus later....
Well I tried 1.47 and 1.49 and is not stable in prime95 or occt.
So back to 8 x 430
3 x yate loons pull 1350, is it hot? Ambient temp is 25 to 29 c
http://i5.tinypic.com/81yg66q.jpg
http://i9.tinypic.com/73l6ujc.jpg
