Hi all,
new version 1.60 is available, with (amongst other things) a new GUI.
http://www.cpuid.com/download/HWMonitor.zip
Please don't hesitate to post a dump if something is wrong.
Hi all,
Nice new GUI! Heres a dump..
Code:Hardware Monitor 1.0.6.0
Mainboard Vendor MICRO-STAR INTERNATIONAL CO.,LTD
Mainboard Model MS-7345 (0x1A0 - 0x5F1CB5)
LPCIO
Vendor Fintek
Model F71882F
Vendor ID 0x1934
Chip ID 0x541
Config Mode I/O address 0x4E
Dump config mode register space, LDN = 0x4
0 1 2 3 4 5 6 7 8 9 A B C D E F
00 FF FF 00 FF FF FF FF 04 FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
20 05 41 20 19 34 00 00 10 40 00 40 60 08 0E 00 00
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 0A 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor
Fintek F71882F hardware monitor
Voltage sensor 0 3.36 Volts [0xD2] (+3.3V)
Voltage sensor 1 1.59 Volts [0xC7] (CPU VCORE)
Voltage sensor 2 1.31 Volts [0xA4] (VIN2)
Voltage sensor 3 1.00 Volts [0x7D] (VIN3)
Voltage sensor 4 0.96 Volts [0x78] (VIN4)
Voltage sensor 5 1.09 Volts [0x88] (VIN5)
Voltage sensor 6 0.90 Volts [0x70] (VIN6)
Voltage sensor 7 3.36 Volts [0xD2] (VSB3V)
Voltage sensor 8 3.22 Volts [0xC9] (VBAT)
Temperature sensor 0 30°C (85°F) [0x1E] (TMPIN0)
Temperature sensor 1 30°C (85°F) [0x1E] (TMPIN1)
Fan sensor 2 1115 RPM [0x541] (FANIN2)
Dump hardware monitor
LPC Register space, base address = 0x0A00
00 FF 03 00 00 FF FF FF FF FF FF 00 00 55 4C 00 00
10 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF
20 D2 C5 A2 7D 78 88 70 D2 C9 FF FF FF FF FF FF FF
30 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF 03 04 10 19 34 FF
60 00 00 00 00 FF FF 02 00 00 00 FF 0E 40 24 FF 08
70 FF FF 1E FF 1D FF 80 FF FF FF FF FF FF FF FF FF
80 FF FF 64 55 64 55 55 46 FF FF FF FF FF FF A8 FF
90 00 0B 0B 00 56 FF 7F FF 41 24 FF AA 55 55 FF 0A
A0 0F FF 00 FF 03 FF 3C 32 28 1E FF E5 CE B7 A0 0D
B0 0F FF 00 FF 03 FF 3C 32 28 1E FF D9 B2 99 80 0E
C0 05 3F 00 FF 03 FF 3C 32 28 1E FF D9 B2 99 80 0F
D0 0F FF 00 80 03 FF 3C 32 28 1E FF D9 B2 99 80 0F
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 00 00 00 00 00 00 3D FF 00 00 FF 00 FF FF FF FF
Hardware monitor
Intel Xeon 3060 hardware monitor
Temperature sensor 0 27°C (80°F) [0x3A] (core #0)
Temperature sensor 1 27°C (80°F) [0x3A] (core #1)
Hardware monitor
GeForce 8800 GTS hardware monitor
Temperature sensor 0 56°C (132°F) [0x38] (GPU Core)
Hardware monitor
HDS725050KLAT80 hardware monitor
Temperature sensor 0 32°C (89°F) [0x20] (HDD)
Hardware monitor
ST3320620AS hardware monitor
Processors Map
Number of processors 1
Number of threads 2
Processor 0
-- Core 0
-- Thread 0
-- Core 1
-- Thread 0
Processors Information
Processor 1 (ID = 0)
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Xeon 3060
Codename Conroe
Specification Intel(R) Xeon(R) CPU 3060 @ 2.40GHz
Package Socket 775 LGA (platform ID = 0h)
CPUID 6.F.6
Extended CPUID 6.F
Core Stepping B2
Technology 65 nm
Core Speed 3606.4 MHz
Stock frequency 2400 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4096 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 9.0x
max VID 1.350 V
Features , VT
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01008003h
Max CPUID level 0000000Ah
Max CPUID ext. level 80000008h
Function eax ebx ecx edx
0x00000000 0x0000000A 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000006F6 0x00020800 0x0000E3BD 0xBFEBFBFF
0x00000002 0x05B0B101 0x005657F0 0x00000000 0x2CB43049
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x04000121 0x01C0003F 0x0000003F 0x00000001
0x00000004 0x04000122 0x01C0003F 0x0000003F 0x00000001
0x00000004 0x04004143 0x03C0003F 0x00000FFF 0x00000001
0x00000005 0x00000040 0x00000040 0x00000003 0x00000020
0x00000006 0x00000001 0x00000002 0x00000001 0x00000000
0x00000007 0x00000000 0x00000000 0x00000000 0x00000000
0x00000008 0x00000400 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07280202 0x00000000 0x00000000 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000001 0x20000000
0x80000002 0x65746E49 0x2952286C 0x6F655820 0x2952286E
0x80000003 0x55504320 0x20202020 0x20202020 0x20202020
0x80000004 0x30363033 0x20402020 0x30342E32 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x10008040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000000
0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
Cache descriptor Level 1 D 32 KB 1 threads
Cache descriptor Level 1 I 32 KB 1 threads
Cache descriptor Level 2 U 4 MB 2 threads
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900
MSR 0x000000E8 edx = 0x00000220 eax = 0x7E0158BF
MSR 0x00000017 edx = 0x00000000 eax = 0x8804892A
MSR 0x000000CD edx = 0x00000000 eax = 0x00000800
MSR 0x0000003F edx = 0x00000000 eax = 0x000000EA
MSR 0x000000CE edx = 0x001B092A eax = 0x7F7F0718
MSR 0x000001A0 edx = 0x00000044 eax = 0x60972489
MSR 0x000000EE edx = 0xA8000000 eax = 0xC17D4300
MSR 0x0000011E edx = 0x00000000 eax = 0xBE702109
MSR 0x0000019C edx = 0x00000000 eax = 0x883A0000
MSR 0x00000198 edx = 0x092A092A eax = 0x0600082A
MSR 0x00000199 edx = 0x00000000 eax = 0x0000082A
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 01008003h
0x00000001 0x000006F6 0x01020800 0x0000E3BD 0xBFEBFBFF
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00800
MSR 0x000000E8 edx = 0x000002A4 eax = 0x7B6DF011
Drive
Name HDS725050KLAT80
Drive
Name ST3320620AS
Drive
Name Corsair TurboFlash
muuuch better now, thnx :up:
i love HWMonitor, excellent job and thank you!
Franck: does this include the K10/790FX voltage mappings?
Thanks as always! :)
Great little utility. A few discrepancies with DFI 965 though. Sent you a dump.lol.
Great job. The voltage reading for my CPU on my P5K is about .875v off. Not too bad. But what does this CPUTIN thing mean? Is that my CPU temp on a diff censor?
Looking good, just need the temps to register in the toolbar. Keep up the good work :up:
does not work correctly on my Asus Striker Extreme ...
:shrug: can it be minimized, so that it´s temp. readings will be seen in the tool bar.
all temps are working in my rig this would relace speedfan/ati tool/smartguardian if i could rename stuff in the gui
few recommendations:
1. a tray icon, or more of them, ability to choose which
2. a log file, of temps, or everything
3. third digit for the voltages
otherwise it's great, I'm using it all the time, instead of dozen other programs, thanks for it :up:
and there should be the minnimum value just like there is a maximum atm,
maximum is fine for temps to see how high they went, but minimum is needed for voltages to see how low they droped
I would love some "events" addeed, i.e shut down computer is fan speed gets to a certain level - just incase my DDC pumps stop :)
This tool is so much better then coretemp. Coretemp would always freeze up my system or hard lock it and cause my system to make an alarm sound.
This utility rocks. Thanks!!
It's reading my system temp at -18c everything else is fine in vista 64.
Probably Tcase.
FYI, for C2Ds, Tcase is a single thermal diode located within the CPU die between the cores and is the sensor your BIOS reads. Not to be confused with Tjunction, which is a thermal sensor integrated within each core.
According to HWMonitor, my "CPUTIN" reads 6c higher than my Q6600's core temperatures. It should be the other way around (if it actually is Tcase) because Tjunction should always read at least 10c higher than Tcase, especially under load. But that's probably more the fault of my BIOS than HWMonitor because my P5K Deluxe mobo is reading my CPU temp 20c above ambient at idle. :mad:
Having the ability to create offsets to correct my problem would be great. :up:
That is what's so good about core temps, they always stay the same, no matter what motherboard you use.
Core Temp is the best, no doubt.
But I use x64 Vista, and if Core Temp worked without having to disable signed drivers I wouldn't use anything else. :up:
And please, don't link me to a site showing how to disable UAC, I know how to do it, it's a royal PITA and it defeats the real reason why i use x64 Vista anyway.
Can we get some sort of graphing ability like systool?
