Originally Posted by
Vampire_Hunter
Yep, missed that one. ;) How much of a difference would the ambient temps affect this if you are measuring the CPU temp to the water temp coming off a block? Seems to me it wouldn't affect it much unless you are running this test bed through a radiator.
So since you didn't test the TDX you have no way of knowing whether your results might show something new, yes? Small differences in testing can create big differences in results, no? Also some of the results shown at aquatuning may very well be within the margin of error. Does anyone here know these guys at Aquatuning so we could get some more information instead of mooing at the moon?
From reading the pic at Aquatuning they showed results with the Swiftech Apogee GTX with the thin type of o-ring. In the side they show the results of the thick o-ring. Is this the same type you tested with? Was your Storm a rev 1 or the rev 2 that Aquatuning used?
Is the order you put the blocks in (that you tested) of some significance here?
Unfortunately, they didn't mention how they did all this, but the important information is the relative index and not the specific temperature deltas, yes? I assume that they have some test bed they use routinely, just like you. Perhaps that information is regularly known to the readers, but not to us. :shrug:
