The system is mine, he told me to keep it yesterday on phone. ;) I only got it to separate FUD from lies from truth around and first hand know what Phenom is like and to share what I find. TBH I don't need it at, I don't need any system more than a P4 and a C2 lappy I have, let alone this PSU is not something I want to use with it, so I'm going to sell it all ASAP. I also have an E6750, two P4 Northwoods, a 5000 BE and an E6850 lying here unused with some mainboards which is all useless, and I need to still test most of them and want to get rid of them before Xmas.
I might still have Phenom by January, who knows. I don't want to, but I'm not sure yet. I'll definitely be picking up the Penryn when it comes though.
As I mentioned elsewhere, if he had a spare PSU bigger than this or if he would've let me keep the 550W S12II I had before this, I would've picked up 4x Powercolor 3870 800/2240 to test with it. They were there unused for the taking but I didn't have a PSU for them. Although I can still get them or two 8800GT's but no PSU for them and apart from running one or two tests, I won't need them so it becomes pointless travelling 1000 miles for it.
I checked out other guys hitting high NB speeds and high HT speeds which means its definitely the board BIOS. I tried it again twice but it only gets to 2.9GHz and freezes at that. It's confusing because the board is very inconsistent. Something is limited and it's not RAM/HT.
BIOS/system only allows tRFC at 26 max. DDR2-1066 won't work despite volts (NB thing), max is ratio 1:2.
Trying to find OC bottleneck, I've tried very low NB speed, very low RAM speed/high timings, very high volts on all things, mid-high PCIe, very low HT speed -> the result is the same so far. :(
I'll test BETA BIOSes and then I'll try to see if I can get it Prime95 stable at 2.6-2.7GHz and the volts needed. Will post temperatures and settings used so it'll be easier for others. ;) I might leave it for a week and play with the 50000 now instead. Should be easy, far easier than this anyway. :)
