Haven't seen any problem w/ the fan on it, by the way His has Samsung memory and mine has qimonda...
one thing..
the 875/1250 bios file is a .sb file.
do I need to rename it to 8751250.bin or will it work as 8751250.sb ?
regards,
Haakon
Cool, I have to try volt modding mine too. I'll have to wait untill tomorrow.
I have a triplex with samsung chips that does 801/1177 fully artifact free, and max stable with artifacts is 801/1285.
Is the bios modding easy? The last time I bios modded was when I had SLI 6800's. Stock speeds were 325/600, max stable was 425/900!!! So I modded them to 400/800.
Time for more fun XD.
Does anyone know if there´s any biosmods for 3870 cards with DDR3 ??
Is there a bios for anything above 877gpu, for a HIS 3870?
I've tried 885 and it seems to be locked at 877.
I have a Gecube 3850 256mb and it crosses 100C as the fan is locked at a lower speed and have to use riva tuner.
I want automatic Variable fan speed BIOS or atleast a BIOS that can make it run at 65%.Help will b appreciated.:)
Buy a fan controller and cram the connector into one of the FC's headers. It works. Over time you might fry the fan controller's resistors so by a cheap one. I've done that both of my 3870x2 and it works great. The only thing (like I said) is that these fans are not electrically equally to a standard case fan so it might bork the FC over time but so far, so good with mine :)
Can it be possible to flash that BIOS to Asus EAH3850 with Glaciator [picture here: http://www.xtremesystems.org/forums/...&postcount=813]? Pencil mod is working, and I reached @ 1,38V that 862MHz core wall.
Flashing with ATI WinFlash is not possible, because of different part numbers or something like this. Should I force-flash it from DOS? My BIOS is 64kb large while that Sapphire BIOS is 61kb, but PCB is AFAIK the same.
