It's a HIGHLY synthetic bench, so depending on what characteristics of the CPU it "presumes" the results can be flawed from 0-100% for any CPU.
AMD delays Phenom 2.4 GHz due to TLB errata
http://www.theinquirer.net/gb/inquir...om-ghz-due-tlb
" While benchmark software vendors had some problems detecting how new memory controller work - both SiSoft Sandra XII and Everest 4.20 were returning single-channel results, regardless of memory controller being used in SC/DC, dual-72-bit or 144-bit- we are still shocked to learn of this situation, that will end up with dire consequences for AMD's management. "
________
This single piece of information clears up several questions that I had gathered recently... even if I don't like the answer...
Poor AMD :(.
Since when is the Inquirer a reputable source of info.. I've seen loads of BS from them before to my recollection. At any rate, this is bad news for AMD's market share to be sure, to quote AMD they can be slower and cheaper, but not slower and more expensive. Price cuts just might make AMD the better deal again, if they can afford it. The low cost and high performance of 690G boards and the Brisbane 4000+ made me choose AMD's 690G platform, maybe they can make their next generation a good deal too.
What I'm really hoping for is a cheap Phenom X4 "black edition" chip. I just missed that one buying my 4000+, but I do still love this little bastard. :) It's marvelously fast, especially at 2887 MHz.
I wanted to build an Octo-Core system since I first heard about it. But now that I see that AMD has pretty much abandoned the QuadFx platform it seams that has gone out the window. Unless of course they Produce a "Black edition" Unlocked Opteron with the ability to run Non-Registered Ram. I've always loved AMD but lately it seams like they are just doing everything wrong. I will still USE an AMD CPU in my next machine, just wish it would be a "4x4" Quad FX like I have been dreaming of since last march. ARe there any Recent benchmarks on running L1N64 +2x Barcelonas? What about OC results? I will be keeping a close eye on this thread until I work up the cash for building my next system.
Welcome. I'm another one who were wishing exactly the same stuff.
A unlocked opteron for common ddr would be great. But, to the moment, what can be done seems to be just to use opterons quad with ecc-ddr on l1n... Seems to be a sad time for the great concept of the dual-socket-quad-cores with ability for oc and high powered videos...
Nevertheless, the statement left a small breech that the concept may be revived in the future. Let's hope something for the 45nm, since there are already the pre-l1a board by asus. If it comes into reallity again, it can become an option for our happiness! :D
Hi i recently bought an L1N64 Board with 2x Athlon 64 FX-74 im using Normal desktop Memory: http://www.newegg.com/Product/Produc...82E16820161183 and a GeForce 8800 GTX, now my quastion:
Would i be able to run an Opteron 2350 or 2344 with just this Memory?
EDIT: I use this system for Gaming and Homenetertainment so i need a Memory, i would be able to Play at least Crysis with!
THX i appreciate any help.
From what I listened at 2cpu.com forums, at least for now, the answer is a sad "no". :(
Last I checked, there's nothing special in the memory controllers that prevent unregistered DDR from working. Just that you can't drive as many memory slots.
The last we all checked, was still dual-core opterons... ;)
Don't get me wrong, you may be right (I would love if that's the case, despite that I would prefer a quad crossfire option board). But the info is too new, the bioses just released, and that's the info I got from 2cpu. ;)
L1N62 will not accept unregistered ram with Barcelona. It won't even post with unregistered ram and Barcelona.
But why is a santa roas warking with unreg. DDR2 als you can see here: http://www.xtremesystems.org/forums/...d.php?t=131691
Or is he using Quad Opterons in this thread? :confused:
Scuttlebut is that ECC ram will work with Barcelona and L1N64 using the hacked bios.
Yes, ECC can be unreg. memory. It can also be reg.
ECC but not reg. example:
KVR533D2E4/2G - Part Detail
Description: 2GB 533MHz DDR2 ECC CL4 DIMM
Detailed Specifications: Standard 256M X 72 ECC 533MHz 240-pin Unbuffered DIMM (SDRAM-DDR2, 1.8V, CL4)
Manufacturer #: N/A
Form Factor: Memory Module
Pieces/Unit: 1
Warranty: Lifetime†
Reg. and ECC:
Kingston 2GB
reg./ECC RoHS
KVR667D2D4P5/2G
Elpida
E5104AG-6E-E
Still awaiting someone to solve the problem of making this problem Octo core with the new Opty's and use unregistered DDr ram at the same time.
I'm still stunned and fel extremely shafted that AMD dropped support for the platform, I mean, they could have done a small run of some modified Quad core Opteron's for the people who paid a fortune for the privelege of owning this sytem, and to dump it like a bad smell was pretty lame from AMD, and why I won't be buying any of their product's in the near future again. The whole reason for this sytem was a stop gap between them geting their Quad's out, annd making the whole thing Octo core, with at least trile SLi, using Two High end card's and the vapourware SLI announcemet that was the third GFX card for physic's.
Absolute nonsense they dropped support for an enthusiast platform considering they are meant to be the enthusiast company, Intel just uns rings around them now, and at least Skulltrail will support everything, including SLI.
New bios... :clap:
ASUS L1N64-SLI-WS
Version: 0401
Change Log:
- Fixed some issue on previous barcelona bios
Download Link:
http://www.esnips.com/doc/7692003c-e...ASUS-WS-B-0401
CAUTION : Reg Dimm only!!!
btw thanks for the support
what was fixed??
For an example of ECC see this post.
http://www.xtremesystems.org/forums/...8&postcount=68
It's ECC but NOT reg. (in the first example)
For an explanation to ECC see:
http://en.wikipedia.org/wiki/Error_d...orrecting_code
ECC doesn't necessarily mean that you have reg. RAM.
If TicTac added reg. support, he basically turned the enthusiast board into a workstation/server board. Either way, as long as the mobo works with the Barcs, people will be relatively happy.
Though, it would've been nice if Asus had done all this :shakes:
EDIT:
It can be both registered (reg.) or unregistered (unreg.) Memory. It's a feature.Quote:
What do you mean? Is ECC unregistered Memory?
So.... you guys have them working anyway Registered ECC and all, but do you have anything to report about overclocking them yet?
