very nice unseen, that evap looks massive, and some nice temps as well.
The copper run between on the second stage compressor, oil sep and de supaheater condenser requires a copper coil between them to reduce vibrations on the joins.
nice temps again Christos:)smothing under load?
well done mate.. nice results and very neat unit
congratz :)
:toast:
very nice unseen
Id love to see the time on a WPRIME 1024 run at those speeds :yepp:
Well done, Crazy fast
Me too ! Hehe...I will try today wprime and i will report.
During the 32m i had ~-91 to the headsprider.
Remember that first of all i am an overclocker not an HVAC guy!
Thats why i am making stuff only for my friends.
Dont wait from me to show you temps from load testers etc by the way...
Thanks guys.
very nicee mate,can u put some prime on four cores?
Woot, I am guessing about -105c on evap than? :)
24/7 on cascade.... I just don't know.... I do it just because I believe in such load test but for cascade, I am not really sure such applies to be honest due to nature of benches lasting not long (shorter the better eh? :P)
sorry my friend but i dont see any reason doing that. The cascade is not for 24/7.
Yesterday i played ~3-4 hours and every time i am benching is for ~4 hours straight if this is ok for you.
@Jinu yes i think the same. The difference between heatsprider temp and evap temp is ~10-12 usally but of course it depends the evap design.
Outstanding work unseen and very good temps, what load would you say you say this chip is pull with this clock and volts?
Really impressive build.
Keep pushing it.
Here is some first results from wprime.
http://i212.photobucket.com/albums/c...25574_6895.jpg
http://i212.photobucket.com/albums/c...407_226309.jpg
very nice unseen, fastest wprime runs for QX9650 on hwbot ;)
They didnt give you many points for that position did they :(
can u test some Q6600 GO clock/fsb
impressive on yorkfield :)
Does the score reflects upon memory for wprime?
I am almost tempted to give it a go by borrowing CPU but won't even bother if it does... I've been out of major overclocking far too long to get to learn how to oc memory well at this point :)
http://www.xtremesystems.org/forums/...d.php?t=161696
@jinu
Wprime needs both cpu+memory to be high overclocked :)
Wholey cow nice setup Unseen.
Those wprime times are insane ,i find tighter timings for wprime is usually giving me faster times than higher ram speeds, and the opposite for superPi
yer i think Prime95 is a usless test if the hardest your gunna run is wprime
i once thought it was good but now i know it is a total waste of time..
it seems to heat cores up insanly compared to what you would use benching for hwbot scores .
somone is gunna be very hapy with that cooler as it looks so tidy..
do you use a controler or wont they read -100c ?
Hori
Finally finished :)
At saturday we have an event here in my city and the cascade will freeze a qx9650 :)
Do you like it in black ?
http://xs122.xs.to/xs122/07493/PICT0005.jpg
It is really nice, great work!
Regards
