I have the F7a :ROTF:
Still Ken, Rapidshare it!
5 months later finally @ retail
will give the x48T a try
Yep it's been a whileQuote:
Just nicely got mine. Gigabyte GA X48T DQ6Quote:
luck:)
Hi Richard,
you may get the F7a bios from Victor's site:
http://bbs.unihw.com/thread-1774-1-1.html
Hi guys, i have just bought x48 dq6 yestrday! Great! nicely running @ 450x8 and mem 800@1066 2.2 volts!
I'm from Maximus formula and i can even reach 1000mhz memory clock on it, the same memory.
Just some question: there are some hidden bios menu like others Giga?
Is there a way to decrease system fan speen by bios ( eg 80% 70% like in asus ? )
i keep followind this thread:)
Is the X48 boards using the new ITE Super I/O, IT8720F...or is it IT8718F?
http://www.clubedohardware.com.br/fu...hp?image=19665
It's darn easy to find out
p.s. What do you think is so interesting about the IT8720F ? :p:
direct link: http://bbs.unihw.com/attachment.php?aid=5238
490 fsb on quad on x48 dq6
http://img147.imageshack.us/img147/8...1808yj6.th.jpg
Thinking of putting a NB waterblock on the X48T anyone got any idea of decent blocks ??
You can choose the Mips X38/X48 NB Block.
I have got made from two guys in Germany special Blocks
http://www.hardware.feichti.com/gfx/...48-dq6-024.jpg http://www.hardware.feichti.com/gfx/...48-dq6-025.jpg
Feichti
Hi Feichti,
Thanks:up: Have you got a link or contact please would be interested in the NB and perhaps the pwm block as well.Quote:
you must love it , if you have to clear cmos with that rig :lol:
thanks again :)
I got a quick question about these boards. Can the backplate be removed easily? Does it come with an alternate mounting kit using nuts and bolts?
Thanks.
For the Mips you can order them directly from MIPS Computer
http://www.mips-computer.de/
for NB you can choose the part MCH025 or MCH1025
for SB you can choose the part MCH026 or MCH1026
for PWM you can choose the part MCH148 or MCH1148
But if you want them to change it to Watercooled i would change all three ot them not only the NB. How you want to cool then the SB and the PWM?
CMOS reset is no probleme because i have made an extension ;)
Yes thats right. Its easy to remove the crazycool backplate. There are also A little New Backplate for the NB and two screews.
Feichti
