gr8 m8 woof.
ach mine doesnt read fillrates or rops or shaders :(
same result as Candyman
works for me but it doesnt read all the info on my card
gr8 m8 woof.
this would be useful to see the improvment ocing makes to the card.
sweet ... now when we going to see some hacked sli drivers for g8's
great program, 10x :)
thanks for the proggie.
good one indeed and helpful.
It is working, but some info are inaccurate ... who needs that program? No one ...
While all is beautiful, I hope the project will continue to develop and will support 100 % of videocards
http://www.techpowerup.com/gpuz/8q23c
tisk, tisk
You might wanna hang up that attitude buddy. The guy didn't create this proggy to annoy you. If you don't find the proggy useful then there are ways to say so without sounding like such a spoilt child.
I suggest you go learn some new phrases.
:shakes:
EDIT...
I've just noticed you're the "17-mobos-whilst-on-same-socket" guy :rofl:
nuff said
Ah where should I place the file? When I run it, the program will crash and say that it cant find a required file.
very cool prog, kinda of redundant but i guess it will be useful for some
Nice little prog...
BUT
In the end, essentially, this has very little use.
Really, for what would one need this?
It's not like CPU-Z which has about 10 usefull strings (CPU + bus freqs + memory timings). Whereas GPU-Z (rip-off name?) only has the GPU clocks of interest. But then again, the usual GPU clock utilities (AtiTool, Rivatuner eg.) also display the temps.
What does GPU-Z has to offer?
:confused:
Could be very useful for GPU overclocks @ HWbot. Just like how you have CPU-Z validation files for overall CPU overclocks, same could easily be done for GPU clocks and use this program. Great program, just need to make it truly standalone(not .NET) :up:
it does not need .net
and yes the name is similar to cpu-z but just to make sure YOU immediately know what it is... also talked to cpu-z author and he said it's ok
largon: have you been around when atitool was version 0.0.5 ? it had nothing to offer over other oc tools as well
Works fine with my 8800GTX and 64bit Vista:
http://www.techpowerup.com/gpuz/f5mng
Good news Wizz, looking forward to this developing into a robust toolkit program.
I havent gone home yet to test it, but does it update clocks on the fly as you OC in Riva/ATITool? I'd like that compared to running the Riva graph to see true clocks.
W1zzard,
I mean GPUs are technically speaking boring.
There's no bus freqs, timings, multipliers, dividers, latencies or cache sizes (of interest).
Just the two proverbial clock frequencies.
So, I take ATiTool will no longer be developed and GPU-Z will take over the OC'ing part too?
If so, sure, bring it on.
BTW, I wonder why some GTS owners (me included) don't get some of the strings displayed; I'm missing "ROPs", "Shaders", "Pixel Fillrate", "Texture" "Fillrate", "Bus Width" and "Bandwidth".
doesn't start on my lappy with RS690M:rolleyes:
how do I make it work? My system becomes buggy after running the program. :(
My media player won't work after a failed run and I cannot bring up the Task Manager with CTRL+ALT+DEL.
Doesnt work on my toshiba A10 laptop ... lol, says no compatable hardware.
I've also got the semi-working 8800GTS.
Cool looking program, hope it keeps getting updated
Would like to see it support the old hardware, including PCI cards if possible.
That way when benching (even SPI) we can just screenshot our CPU-Z and GPU-Z, and no longer need to list hardware.
It don't work with my Go 6800 Ultra... Will try on my X800 GTO AGP card.
EDIT: don't work on GeForce 2 cards eather.
Pretty good utility.
It works normal for me :D
http://www.imgx.org/pfiles/2433/untitled.PNG
The shader clock monitor seems to have some kind of bug, it should have been 1776mhz. But lets wait for updates :D
