Im at 692/1754/1962(981) :)
Man I feel like I got a dud. Have you volt modded the card at all?
Wow?!
What voltages are you pumping into that card?!
It didnt work for me on an 8800GTX, restarted, with 163.67.
That solved it for me.Quote:
This worked for me......
Power User>Rivatuner\System>NVAPIUsageBehavior set value to 1
Apply, close out, then reopen and the shader slider should be there.
I alpha tested this. was nice to see the changes it went through. development was amazingly fast FYI.
Hmmm.. makes me wonder if in the future it will be possible to change the shader clocks independantly for the R600... :yepp:
I have a 80MM fan blowing over the backside of the GPU but I didn't notice a difference either.
Ive been using the OpenGL Fur Benchmark to judge stability, and OC merit (whether stressing my card more is worth it...)...
I like that bench a lot because it is the only one that doesnt give me crappy scores based on my crappy CPU/RAM/Motherboard... :ROTF:
I just finished 2 hours of testing running the latest fur and surface deformer benchmarks I could not beat the scores I've gotten using ntune.
Did you OC the shaders? I got from 2108 score, just using nTune, to 2227 after Rivatuning my shaders... XD
yes, I screwed around with it until I had max clock on everything. 770 core 1800 shader was starting to artifact and could not beat my ntune score in fur.
What resolution?
Driver 163.71 xp64 CPU at 3.7 ram 1000 4-4-4-5
Attachment 65069
Cheers, dengyong! :)
The extra ROPs 'n' shaders on GTX seem to be scaling nicely, as a comparison my GTS @ the same (ROP/shader) clocks does 13.5k with a 3.6GHz quad and DDR2-802 @ 4-4-4-10.
btw, I take that's with linked shader clock, yes?
Yes, with ntune.
