i'm using the new kit with same settings and it is stable. no errors. no BSOD. weird and strange. don't know what the problem was with the rma'd kit.
let's see what my kit can do with p5k3 :D
trying to run the kit @1960 87621 2v 400x9
but no luck
trying 480x8 1960 876 1,9v and it works so i guess the divider doesn't work
I can not figure out which RAM multiplier you are using. With FSB 400 MHz and the biggest RAM multiplier (FSB:RAM=1:2) you can do DDR3-1600 and not more. :confused:
Anyway, you have to consider the NB strap, with 266 NB strap it is hard to reach RAM frequency close to 2000 MHz, with 200 NB strap it is quite impossible (when you choose RAM multiplier you change the NB strap if you do not fix it from bios setting "NB strap frequency").
rufusz used the orange slots.
i tried the orange slots here as well and i have the exact same problem as rufusz. but in the black slots the kit passed orthos for 5 hours at 1950 876-21 with 1.8 or 1.85v, dont remember exactly.
hmmm how about it rufusz, should i see how high they clock with 765 just to annoy you? heheheh :D
oktoberfest? :D if your coming let me know so we can meet up hehehe :D
ok, let me check :D
about the orange slots... yeah... some sticks can run well in the orange slots too, but they will run even better in the black slots in my experience :D
EDIT: 1830 765-18 1.9v stable :D
i really wonder why the orange slots are worse... i think its the voltage...
running mine at 1850 7 6 5 18 with 1,9 on my p5k3..but there's sth wrong i set to 1t on bios and cpuz keeps showing me 2t
good i should try to run some test bandwidth of the rams to see the diffference then :D
here's a screenie
http://www.pctuner.info/up/results/_...5_q6600new.JPG
so is it just cpuz?
if yes then lmk and i can ask franck to have a look at it.
Having a little play with mine for a while.
Q6600 G0 / Intel HSF 400x8
Asus P5K3D
Cellies @ 1600 / 7-6-5-18 1T (uncooled)
Primed for 30 minutes til the CPU hit 80C lol, Cellies got warm too at 1.8v. Then I started dropping the vdimm and got down to 1.65v stable, SPi 1M 15.75s. Windaz fell over at 1.6v, so stability must lay between 1.6 - 1.65. That's quite tantalising, hope it scales when I start to push them a bit with some cooling.
my cellshock DDR3 arrived this morning :D
http://pics.mwirths.de/pics/thumb/cellshock.JPG
http://pics.mwirths.de/pics/thumb/cellshock_02.JPG
http://pics.mwirths.de/pics/thumb/cellshock_03.JPG
but no DDR3-Board :(
