:banana: :toast: :banana:
Absolutely Beautiful Work! Man, even though it might not be worth 250 for the temps but it's definitely worth it for the craftmanship! I always love quality work.
Thanks for sharing,
R
Thanks for sharing,
R
Very nice copyman, that is for sure. I am interested to see single fan version, about the size of a D-Tek core, about 6x6 inches. The thing that is not computing in my head is this: When straight watercooling with radiators (no pelts etc.) the best the radiator can theoretically do is get the H20 to ambient temps, no lower. Now as inefficient as a heatercore may appear to be, they still perform very well. Cathar's Big Arse rad keeps H20 temps at about 1C over ambient, and that is a dual fan heatercore. Point is, I just don't see how the F2 is leaps and bounds better. I believe it is a very good rad, paired with a very good pump paired with a very good block. When my ambient temps are as low as yours, I get very similar overclocks as you with my water setup and I use a D-Tek heatercore paired with a WW and Cascade and an Iwaki pump. Like I said, I'd love to see a 1 fan version. My new setup is going to run 2 heatercores in parallel.
SEE WELL, YOU ROTATE TO 3600MHZ IT USES 1,65V OF VCORE, IT ROTATES YOUR P4 FOR 250MHZ THE MINUS, IT USES A BOMB THAT REVIEWS 1\4 OF THE HEAT COMPARED WITH MINE, AND IT USES A MORE EFFICIENT BLOCK THAN LRWWQuote:
I ROTATE 3850MHZ 1,82 VCORE, (THAT SHOULD GIVE 35% MORE THE OF HEAT) I REVIEW 4 TIMES MORE HEAT FOR WATERS WITH MY PUMP AND MY WATERBLOCK IT LOSES ABOUT 1C OF DELTA AND 3 C OF TEMPERATURE FOR YOURS.
IF THE MEASURES COULD BE MADE HER I PROPAGATE WAY AS I SPOKE, AND YOUR TEMPS ROOT THE SAME ONES MY SYSTEM IT WOULD BE MORE THAN 30% MORE EFFICIENT THAN YOURS IN THE SAME CONDITIONS, BUT LOGICAL THAT IS NOT.
BUT SUPPOSING THAT WE USED THE SAME SYSTEM, LESS RAD, IF TWO RADS GET THE SAME TEMPERATURE OF THE IT LONGS FOR I WOULD STILL TAKE AN ENORMOUS ADVANTAGE OF YOU, MY RAD AND 3X LESS RESTRICTIVE THAN DTEK, AND TEMP AND DELTA WITH MY RAD IT WOULD BE RESPECTIVELY LOWER and SMALLER.
ANOTHER POINT, THE GREATNESS OF THE DIFFERENCES OF TEMPERATURE IS THE MORE LARGER HEAT YOU HAVE TO DISSIPATE, TWO DIFFERENT SYSTEMS CAN HAVE RESULTS SEEMED TO 150W, BUT TOTALLY DIFFERENT TO 200W, THE DIFFERENCES BECOME MORE YOU OBVIATE AND OF LARGER GREATNESS THE MORE HEAT YOU HAVE TO DISSIPATE
I AM VERY FAR AWAY OF ARRIVING TO THE LIMIT OF SATURATION OF MY SYSTEM, FOR THAT I CAN USE A PUMP THAT REVIEWS LARGER HEAT FOR IT WATERS HER, LOOK WELL AT YOUR DTEK, LOOK AT YOUR FLATS IN FORM OF Z, LOOK AT THE DOUBLE PASS THAT YOU DO,
IT IS NOT BY CHANCE THAT I HAVE AROUND 40 LITERS PER MINUTE IN MY CIRCUIT.
IS TO COMPARE MY RAD WITH A DTEK A FIGHT BETWEEN MICKEY MOUSE AND GODZILA, DO I KNOW, BUT YOU THAT WANTED TO COMPARE WERE NOT?
THAT IS ALONE SOME OBSERVATIONS, I COULD SPEAK ONE DAY I FIND OUT HERE, BUT FACT IS THAT, THE LEVELS OF OVERCLOCK IN AMD AND IN P4 THAT I GET AND WITH TEMPS THAT I GET, THEY WERE NOT STILL REACHED WITH ANY OTHER SYSTEM IN THE WORLD WITH WC
THANK'S FRIEND
FOR THAT THAT I SENT ONE FOR CATHAR AND I AM SENDING A SYSTEM FOR OVERCLOCKERS, IF YOU ARE FRIGHTENED WITH WHAT MAKES LRWW AND YOUR 0,18 C\W TO 12 LITERS PER MINUTE, IMAGINE WHAT HE WILL DO WITH CLOSE TO 13 LITERS FOR MINUTE WITH THE TEMPERATURE HIGHLY CONTROLLEDQuote:
Originally posted by Craig
It will be interesting indeed to see what Cathar's testing with a F2 and his new Cascade block shows. And Cathar has a MD-30rlzt whick while it doesn't give the same massive total flow of Copyman's quietone pump has a huge amount of head (pressure) while pumping 4.6gpm.
Cathar's results will be your best chance Copyman for some major notice. Cathar is extremly respected and for good reason.
If your F2 turns out to be the rad version of a LRWW or a Cascade you'll be selling many of them. Most would have to be the lower cost model but I'll bet they will sell well.
UNHAPPILY SAME BEING A DOS FIRST TO BUY SOME PIECES OF CASCADE, THEY ARE LONG TO ARRIVE HERE.
IN CHAT DEPRIVED WITH CATHAR HE SPOKE TO ME THAT WAS MAKING TESTS WITH TWO DTEKS IN PARALLEL, CASCADE, AND IWK 30 IN A XP 2400 @ 2690MHZ, AND YOUR RESULTS WERE AT THAT TIME WORSE THAN MINE, AND I USED A DTEK MODIFIED TC4, A MAG DRIVE 700 AND PROTO IN THE 5 OF F2, OH I ALREADY ROTATED MY XP 1700+ TO 2733MHZ 2,125 VCORE, WITH LRWW AND QUIET ONE I JUMPED FOR 2744 MHZ, MY TEMPS LOWERED 3C AND 1C OF DELTA.
COMMERCIAL RADIATOR DOESN'T EXIST IN THE WORLD TO NOT TO BE F2 THAT GETS TO 20C TEMPERATURE OF ROOM, TO ROTATE TO 2700MHZ TO 2,1 V WITHOUT THE TEMPERATURE OF THE IT WATERS TO GO ARISING TO THE PROCESSOR TO SATURATE, I HAVE ABOUT 10 COMMERCIAL RADS HERE, OF DTEK TO BLACK ice extreme, NONE OF THEM WAS LAYERS OF MAINTAINING THE TEMPERATURE OF THE IT LONGS FOR BELOW 1C OF DIFFERENCE FOR THE TEMPERATURE OF ROOM, ALL OF THEM, I REPEAT, ALL OF THEM HEATED UP THE TEMPERATURE OF THE IT WATERS MORE THAN 5C ABOVE THE TEMPERATURE OF ROOM TO THE PROCESSOR TO FAIL
excuse my keyboard to have joined the caps look
Thanks friend
I know that I speak a lot, but I know how to hear also, for that I am here with two cores of 6 " x 5 " and another of 6 " 6,6 " to set up and to test, I also offer to send one of those rads for anybody that wants an and have a system amd that is at least generating above 180w for the calculations of the bench test, without some costs, for us to see the differences of my construction method compared with any other.
ps=I feel happy for having technical inquiries now instead of only inquiries of prices, I make that for love, and I want more than to sell radiators to convince the wc users that they can go well far away than they are going, excuse my English once again, it can be that in some moment I seem aggressive, but it is alone difficulty in writing in English
thank you very much to all
New cores with dual fan soon, inside of some days new rads F2 in the sizes of it cores of
6,5"x 6 (48 flat tubes) and 5 " x 6 " (40 flat tubes) using the same technology and materials
Thank you very much to all
Ivo Guilhon (Copyman)
damn, i want one, i would take it if the price was like 150 maybe, but 250 is crazy for a bunch of fine tuned metal.
You can have the less beautiful version for 130$Quote:
I want one.
Stunning work copyman, just stunning.
Sorry, but this kicks any heatercores butt big style, and i'm a big fan of heatercores.
Well, more like 3-3.5C over depending on what you're throwing at it.Quote:
Cathar, how soon are you going to test copyman's rad?Quote:
I would like to explain something, I send a rad for the cathar without his purpose to post or to test for the public, but for him to test for an interest peculiar of him, he doesn't have any commitment with me of publishing any data on the rad, that will depend on your willQuote:
I am trying to send for Joe a rad it is still a complete kit with the cascade, but he informed not to be ready for you test them on that moment, I am awaiting
copyman, I really admire your craftmanship. That radiator is a thing of beauty. I do not any watercooling experience to pass any kind of technical judgment on its functionality, but for some reason I tend to believe what you claim.Quote:
I am hopeful that Cathar will be truly impressed with your product and share that with everyone here. I will say that he is very well known and respected here, so whatever his opinion, I believe it will carry great weight.
