Alright, Part 3, Heatsink Comparison is completed at the main thread.
Here are the summary tables:
Thermalright IFX-14 vs Ultra 120X, Single Fan Configurations
http://img.photobucket.com/albums/v3...singlefans.jpg
Notes: all testing for the IFX-14 was done with the fan in the middle position (between sink towers)
and for the Ultra120X in the Pull configuration (Pulling air thru the tower sink).
Flames indicate where the cpu failed due to overheating. 75c probably doesn’t represent an accurate temp, as the cpu automatically terminated its load.
Well, with a low speed fan, the Ultra120X actually failed. Its not so surprising as the heatsink tower has fins that are very dense, as well as large in surface area. The IFX-14 appears to have the same density, but breaks the surface area into 2 towers.
However, once you get some fans with some oomph, the 2 heatsinks performed virtually identically. Maybe the slightest edge to the Ultra120X with 38mm thick fans.
http://img.photobucket.com/albums/v3...emultifans.jpg
Notes: Best Mod mode for the Ultra120X was Push-Pull Panaflo M1's. Best Mod mode for the IFX-14 was Delta25 - Panaflo M1 - Panaflo M1 + 80mm fan on the backside cooler.
With 2 fans, the Ultra120X gains a small edge.
However, in the best mod mode, you can strap 4 fans to the IFX-14! The 2 best mod configurations are pretty equal in sound, but the IFX-14 gains a 1.3c advantage. The ability to use more fans increases its performance, with minimal addition to noise.
IFX-14 vs Ultra120X comments
Well, I think its much more complicated than saying one heatsink is better than another. They always performed within 1-2c of each other. As of the writing of this article, the IFX-14 is some $30 more than the Ultra 120X. If you are looking for that extra money to translate directly into higher performance, you will be disappointed.
What DO you get for that extra money.
1) A much better mounting mechanism.
2) Significantly better performance if you are looking at using only ONE low speed fan, and generally better performance for low noise solutions (for example 3 yate loons is quiet yet performs quite well).
3) Native support for multiple fan configurations (Recall the Ultra 120 requires modding to support a second fan).
There may be other differences, which I haven’t specifically pointed out. For example, with my IP-35, the IFX-14 consistently beat out the Ultra120X in PWM temps.
On the downside (besides the price), the IFX-14 is enormous, which may interfere with large gpu coolers, nb coolers, or active RAM cooling.
