Update (19-Aug-07): Outer Panels
Just a small update today; but it give a good perspective of what the finished product will look like
Sanded the edges to blend the corners together
http://ocidb.com/albums/userpics/100...r-Panels24.jpg
Assembled the panels with switches and FPIO to give an idea of how the case will look
http://ocidb.com/albums/userpics/10005/Case1.jpg
I still have to polish up the edges and install the drive bays; then the case itself will be basically complete.
Sponsors:
http://ocidb.com/albums/userpics/10005/DangerDen.jpg http://ocidb.com/albums/userpics/10005/A_C_Ryan.jpg http://ocidb.com/albums/userpics/10005/PTS.jpg
Petra's Tech Shop Sponsorship
I've also received support from Petra's Tech Shop
Here's what they sent me: Acrylic LED case feet, 3x 120mm chrome fan grills, and water additives (Biocide & Blue, Green, and Red dyes)
http://ocidb.com/albums/userpics/10005/PTS1.jpg
The LED feet and wiring harnesses
http://ocidb.com/albums/userpics/10005/PTS2.jpg
Case feet in action
http://ocidb.com/albums/userpics/10005/PTS3.jpg
One drawback to the controller for the LEDs is that it defaults to a flashing mode when it's turned on; but I'll be eliminating the controller and connecting them directly to a switched 12V line, so that won't be an issue for me.
Sponsors:
Update (27-AUG-2007): Outer Panels & Drive Bays
Update (28-Aug-2007): Drive bays & Case
Update (02-Sept-2007): Fan & Lighting Controller
I finished making my PWM fan and lighting controller. It has 8 fan channels and 4 lighting channels (1 dedicated to the fan lighting). The fan LEDs are connected to separate headers from the fan itself.
First: the circuit I used
http://ocidb.com/albums/userpics/100...ol_circuit.jpg
Installed 1 fan control channel to work out the layout
http://ocidb.com/albums/userpics/100...n_control1.jpg
Here in the US I wasn't able to find anyplace that had the MIC502 fan control IC available in a DIP package; so I had to make due with the SMD version
http://ocidb.com/albums/userpics/100...n_control2.jpg
Soldering on leads
http://ocidb.com/albums/userpics/100...n_control3.jpg
1 DIPicized IC
http://ocidb.com/albums/userpics/100...n_control4.jpg
All eight channels integrated on the PCB
http://ocidb.com/albums/userpics/100...n_control5.jpg
Added power supply as well as headers for the fan LEDs and fan LED switch
http://ocidb.com/albums/userpics/100...n_control6.jpg
Also installed headers for the case lighting control
http://ocidb.com/albums/userpics/100...n_control7.jpg
And a pass-through MOLEX connector
http://ocidb.com/albums/userpics/100...n_control8.jpg
The underside of the controller
http://ocidb.com/albums/userpics/100...n_control9.jpg
The wiring for the power connectors will also be sleeved later on in the project.
Sponsors:
Update (02-Sept-2007): Cabling
Update (03-Sept-2007): Cabling & Base
