This is not just a belief it is a fact. Bowed pwns unbowed on IHS. In my test by as much as 5c or so on a 6600.
THIS THING IS GOING TO DIE IN A DESKTOP (desktop case, the ones you put onto your desk under the monitor) SYSTEM, SO KEEP IT AWAY FROM HTPCs :fact:
DDC is not supposed to run top-side down, you better add this on the swifty page ;) , in a normal ATX case the design looks good, but this thing is going to make res placing even harder...
EDIT: i killed my DDC-1 pro this way, together with my ultra-d (cpu+vga survived)
interesting, nice little startup kit you got there gabe and im glad someone finally put out a halfway decent product to compete against that crap thermaltake has been putting out. I hope this gives you some more market share :)
And Nicks contributes how to this watercooling forum? I'd trust Gabe with regards to measured heatload over someone who rarely contributes to this forum. I see no reason for Gabe to lie about this. If anything wouldn't he want to report a higher heat output so that he'd sell more radiators than would be necessary?
Gabe,Quote:
"So we added a reservoir to the existing Quiet Power MCR120 radiator"
http://swiftech.com/products/H20-120-COMPACT.asp
Do you know whether or not the integrated "res+rad" will come in bigger variants? This would be real nice - to not have a reservoir anymore!
I agree, your temps would be acceptable but I could see them rising very quickly when gaming or benching.
Now dinos22, we've had our disagreements but man, if you have a problem PM me.
I contribute. Just because I don't like your overall "in your face" and "I'm right you're wrong" attitude doesn't mean I don't contribute. That and, where did I ever say anything to Gabe about heat load. This is my first post in this thread. :confused: I believe Gabe too. If he has the right equipment necessary to gather the information & the equipment was used properly, then there is no reason there would be an error in his measurements.
PM me man, we obviously have some disputes that need working out.
So, I think I'm ready to dive in being I need something compact. Where can I get one in the US market right now... if not now, release date?
I removed the word "Desktop" to prevent any misunderstandings.
The pump CAN perfectly operate upside down, but the system needs to be bled perfectly (when bleeding upside down, an air bubble could be trapped in the bearing area and woud stay there forever unless the pump is bled right side up). So we end not recommending upside down operations to avoid problems.
Heh, just saw this topic as I was offline tweaking my WC a bit. I couldn't help but think of this when I saw the combo'd pump/block. That's been up for well over 1½ years IIRC.
Gabe, any chance that an old Apogee can be modded to fit the bottom of that?
Hmmm... I will have a poke around to see if I can source the relevant O-ring.
As I said before, I tend to be quite thick sometimes. Or saying it in a way that's not so derogatory, I can't see the wood for the trees.
I had the impression that the bowing business was GTX "onry". Don't ask me why because I don't have a clue where I got the idea from. One of these silly things that sticks to your mind, like "fill your rad with vinegar and leave it there for a week, is great"...
Sure.. This concept has been around for a while. We are not claiming the invention of the water block (public domain) nor the invention of the DDC pump (covered by multiple patents already), but a means of converting the DDC into a water-block.
Let me give you a parallel: long time ago, in a far far away galaxy, someone had invented the pencil and got a patent for it. In another galaxy, someone had invented the eraser, and got a patent for it. Then came a third person who had the idea to put an eraser on a pencil, and file a patent for it, but the patent application was rejected by the US patent office.
Anyways, the revolution in our mind is the fact that we are combining two high-end technologies, the DDC and the Apogee, to provide high-end performance in an economical package.
As to conversion, sorry but it is not possible mechanically.
Sorry, didn't mean to imply anything of the sort. I just thought it was neat someone had finally followed through commercially on the concept. As much as I like my CSP's, I like my DDC's even better.
...again I think there's a misunderstanding. I meant with your setup, not the CSP...or is there a difference between the Apogee bases for your setup and a regular block?
what if you want to mount this outside, is that an option?
or gabe, on page 1 you said you put this in your p180. my p180 is pretty full, where could the radiator fit?
and i am talkin about the 220 size not the 120.
