Hmmm that is a puzzler.
I tried with C&Q ON and OFF with 4,4,4,12,2t......but get the same each time. My COPY even exceeds my READ now....this is crazy..lol
mofo, whats your asynch lat? and other mem timings?
omg im blind rofl...
smth is really weird there. can you use everest 4.0 insted of 4.1beta?
well i have a possible answer for the copy bandwidth -
soldner, try using rightmark cpu utility to lock your multi at.... god this is confusing... lock at 6X (should give a mem speed of the same as current using - check with whatever app you like) then re-run. does the copy mb/s become even more out of line? (i expect all to drop by >1/2, but copy to drop less so) if so mine does the same and it seems to be an oddity of the amd mem controler - raw thruput is heavily reliant on mhz, but copying data is more reliant on memory. eg, faster memory/slower cpu = copy out performs read/write. faster cpu than ram, and read/write perform better. - doing this for me takes me from a copy of ~6700 to ~4800 read drops from ~8K to ~4K. (i start with slower ram vs core speed while you have much faster ram, not much more core speed)
also, new and improved iffy-marks tm incomming...
no C+Q = 7790 / 7894 / 6767
http://img441.imageshack.us/img441/4...titled1vl7.jpg
classic ddr @ 258mhz 3-3-3-8 1T v close to DDR2 @ 459 4-4-4-12 2T.... not likely
- bahavior exactly the same under V4.00
That is very strange indeed. I'll try as you suggest with rightmark to see if you're right. I'm updating the NUC thread offline just now so it may take me a while to edit this.
heres mine tracer 2x512 pc8000 at 2.24 volts 4-4-4-9 all bios boot no memset changes. this is 24/7 setup
1340 mhz at those timings is just insane!!
this is the best i can do with this memory... can go to 512mhz cl5, but 492mhz Cl4 gives better result.
pretty good for cheap DDR2 333mhz :p:
2 X 1GB Crucial Ballistix Tracers DDR2-800
http://img.photobucket.com/albums/v1...pdog/28512.jpg
I used to have some OCZ PC4800 Platimum Elite editions that would run at 2-2-2-2 but unfortunately I never had anything better then a XP2500+ to run them with. Wish I had kep them for nastalgia purposes. God those were some awsome stix. About the only chips better, ever, were the BH5 chips.
not good :shrug:
2*512mb corsair 8500
http://img480.imageshack.us/img480/2327/adsz2gs2.jpg
have 4 gigs gskill 6400hz,s but currently using my 2 gig kit of ocz. 2.2 volts is the max on my biostar 965pt and to be honest i dont think i need anymore.
http://i76.photobucket.com/albums/j1...ut/ddr1140.jpg
http://img165.imageshack.us/img165/2718/membandmy6.jpg
http://img171.imageshack.us/img171/1073/memff8.jpg
Not BAD for 408MHz, 5-5-5-15 timings.
I can't get board to run my HZs at the 520MHz @ 4-4-4-12 that my DS3 used to :( It crashes on post. When I manage it, I'll re-do it, should be much higher that it was on the DS3..
Everest Ultimate 4.10.1142 beta
41.1ns latency!
http://fileshosts.com/intel/Asus/P5K...-bandwidth.png
Sandra 2008 XII - Buffered and Unbuffered
10200+ MB/s Buffered and 7000+ MB/s Unbuffered!
http://fileshosts.com/intel/Asus/P5K...i/mem-buff.png
http://fileshosts.com/intel/Asus/P5K...unbuff_spd.png
