finally an update keep em coming!
Nice work! Can't wait to see what you do as far as getting everyting organized.
nice cutting there
looks absolutely fantastic.. keep the pics coming brotha.. cant wait to see it finished :up:
90% done i ran out of thermal compound so i am waiting on some to apply to my 8800gts also have 2 more uv lights to install
http://i187.photobucket.com/albums/x...cture005-3.jpg
http://i187.photobucket.com/albums/x...cture006-3.jpg
http://i187.photobucket.com/albums/x...cture007-2.jpg
http://i187.photobucket.com/albums/x...cture008-2.jpg
http://i187.photobucket.com/albums/x...cture009-1.jpg
http://i187.photobucket.com/albums/x...cture010-2.jpg
http://i187.photobucket.com/albums/x...cture011-1.jpg
http://i187.photobucket.com/albums/x...Picture012.jpg
:up: Pretty!
looking good :up:
Just a question on the fill port... Looks a little odd with it just kinda hanging out there with it's 6 or so inches of tubing. I haven't built my first real system yet myself, it's on the way via UPS, but it might look a bit cleaner to shorten that tubing for the fillport down to the minimum so it's just basically that fill port sticking up and not taking up more space. Just an idea.... ?
i finally have my system up and running i have my q6600 g0 overclock to 3.1 to start off and all cores are under 30c and thats with d5 only set to 1
just when you thought it was done i come back with something else this time i brought lian li wheels and stuck them on with 3m double sided tape and it doesnt stop there because coming soon i will update my cooling system and be upgrading my stock fan mesh with modders mesh to increase airflow
http://i187.photobucket.com/albums/x...86/Picture.jpg
i cut my grills out of modders mesh now all that is left to do is paint them but not sure weather i should paint it gloss black or flat help me decide
Nice build. Makes me want to get a case like that. I need a bit more room than what I have now. A PA120.3 on top of a case does not look very good.
at first i used a dremel but that didnt work out at all it was to hard to control all my cuts were going crazy so then i thought about wire cutters and that worked out great edges are all even and clean cut but i decided to paint grills gloss black
lol I'm doing the same as you.But with my v2000 cutting my modder's mesh now.Had a hard time cutting it with a dremel aswell so i used my wire cutters .....
I also have gloss black paint and will be painting it this w/e
Wipe it down with some lacquer thinner 1st then light sand then paint....
i was just going to wash it with some soap spray it with some self etching primer then paint why do i have to use laquer and sand it
since the modders mesh will show more of the fans at the bottom i had to sleeve my cables and also have gotten a new set of toys
http://i187.photobucket.com/albums/x...cture007-3.jpg
http://i187.photobucket.com/albums/x...cture008-3.jpg
I don't know that what i was advised to do....Quote:
nice memory,i also see you don't have cpu (in you sig) which one are you going with?
i have a core 2 extreme x6800 but dont know if i want to keep it
revising my watercooling setup first was the rad i droped the mcr220 and kept the mcr320 but added 2 more fans so now it will cool better also had to do a simple nut and bolt mod to hold l bracket steady here are pics
http://i187.photobucket.com/albums/x...cture001-5.jpg
http://i187.photobucket.com/albums/x...cture002-4.jpg
http://i187.photobucket.com/albums/x...cture003-3.jpg
Stanford & Sharpie = Great 'paint' job ;)
Nice mounting idea/bracket!
