Thinking about getting a DS3R now
congratz Pt1t :)
very nice clocks.. :)
:clap: :clap: :clap:
amazing
only 2.5v
Ok, so are you still testing the Gigabyte board so far? Will you be posting clocks of the other boards in the next 2 weeks? So far from everything I've been seeing in 3 forums it seems this Gigabyte is the fastest, highest overclocking P35 out to date. Could someone tell me different?
One Attempt under LN2 but My DQ6 did 750 max :shocked:
http://www.pt1t.net/DDR2/crucial_underLN2.JPG
750 fsb??? WOW :shocked:
Did you test this ram on a 965 board? If so what was the max? Thanks.
Im rather sure thats why im asking got one on the way ;)
I had ~720 on P5bdlx C1 , but i think C2 ll do more ...
I also Have Max 710 on P5k , 743 on p5k dlx , 750 on 2 P35 DQ6, 747 on DS3P :D
I'm looking closely at which of the p35 boards will yield consistant high fsb to ram clocks.
What are the differences between P35-DS3R and P35-DS3P?
I'm waiting your opinion about the best P35 board. Thanks for the hard work!
Surely the WR DDR2 CAS5 is Pt1t's !!!
to dinos22 : your URL of CPU valitation ,it's DDR3 heyhey
But does the Gigabyte MB officially support both DDRII and DDRIII :fact:
If that was a question, then yes, it supports both, but not at the same time. You can use either DDR2 or DDR3, not DDR2 and DDR3.
wow those timings will kill gaming performance for sure ouch!!!!!
speeds>timings, especially at this magnitude
ddr3 is already flying.
anymore results.. :drools:
I've ordered a P35C-DS3R and was looking at one the cheaper Core 2 Duo Processors to partner it, then I saw this ...
"Intel plans to slash prices 40-60% for quad-core server processors in July. The Kentsfield Xeon X3210 and X3220 will have their prices cut to US$224 and US$266 respectively"
http://www.digitimes.com/mobos/a20070521PD201.html
