Performance is the same between the 2/3 barb versions. The 2-barb version has a tweaked inner chamber to facilitate better flow.Quote:
Originally posted by antipop
Have you noticed a diff between the two barbs and three barbs version?
Nice job, it could be nice with a blue led
You could stick a blue led in it if you wish. I won't provide a hole for you, but the top polycarb plate is 10mm thick, of which 2mm is taken up by the O-ring, so that would give you 8mm of thickness to drill into and stick some LEDs in. I'd do it from any side except the side that has the outlet barb on it.
Actually the fact that it's clear is somewhat important. It allows a visual check to see that the jet tubes are aligned with the holes when clamping the block together, so the clarity does serve a function, rather than merely just for looks.
