BR, did you say 'which' S-Flex fan you tested with anywhere? (RPM, CFM, dBA?)
This looks like the perfect HSF for me, if I can figure out what fan to use :). It seems like the 92mm fans would have less dead-spot issue at the hub, but quieter 120mm fans can be found with better cfm/noise ratios.
