I can tell you a Quad @ 1.75 will draw 570W ALONE :eek:
But don't you have to crossload the 5v rail when using a PSU for 12v to keep the rails stable?Quote:
One is main.....Second is only for fans.....The other two for the VGA's are OK....
I've tested about other 4 with no luck......They didn't start without drawing currents and one Forton, shuted down from overcurrent protection while the VGA was under full load....
Very impressive... keep it up!
Today here in Hellas, IS Sunday.....Now that I'm writing, it's 8:26am here.....At 10:00am we will have a party here at my place......55kgrs of LN2 are ready, hardware is ready and tested, so wish us luck......:D :toast:Quote:
Originally Posted by blind_ripper
σας εύχομαι την τύχη
And waiting for those big numbers and WR too :slobber:
Good luck & have fun ! :toast:
Thank you guys..... :) :toast:
Yes we will have a LOT of photos and Videos.....:D
Good luck there :)
Good luck and have fun.
Smash them WR's!
Go for it George.Good luck:toast:
Good luck:toast:
Have fun, hopefully everything will go fine ;)
Good luck hipro!
Some PSU's have a build in compensation for unloaded voltrails to prevent the PSU from malfunctioning, atleast that's what I've been told :)
EDIT: and you can mod your PSU to propper work while unloaded.
He can't run behind us, Greece is located more to the east compared to Belgium. Now if you keep in mind that "The sun always comes up in the east", you know that people in the east will see the sun appaering earlier than us Belgians, so they are in front of us. When it's 8AM here, it's 9AM in greece. :)
Good luck with your benching hipro :toast:
@k|ngp|n
that is Tron 2 in your sig , right ? :stick:
I think I'm in late for say "good luck" :slapass: :D
any news ? 3d 200... ??? :D
Any results yet? I'm looking forward to see them ;) I'm sure you're having alot of fun :D
Hello there guys....:)
My first run of SLI went under disaster.... :(
I have tested before the one VGA and I knew what it wanted for VGPU and VGDDR and I was OK as for this part....
The other VGA wasn't tested well due to luck of LN2 so we came to "yesterday"..... :(
BOTH couldn't bench at 974MHz core.... :( OR - to be more specific - to understand that the second VGA wanted LESS VGPU to work that high, it took me all of my LN2...... :(
Nothing good for the time been.....
After the big disappointment and left with few LN2, I dry them out and switched mobos.....
I placed my X6800 onto ABIT AW9D-MAX one and benched Aquamark with the first VGA that I knew its reactions.....
It was a bit easy I could say to bench her at 974/1244MHz but I preferred to bench her at 974/1215MHz to be sure....
I took this score which satisfied me for the time been.... :)
http://www.thelab.gr/images/Hipro5/A...3_974_1215.png
....and this is the file of it: CLICK ON ME...
NEXT time I know what to do though, how high and with what voltages I'll play.... The frequencies will be 974MHz core and 1244MHz rams.....One VGA to do so, needs 1.74VGPU and the other one 1.69VCore....except the 2k1 where the first needs 1.79VGPU and the second 1.75VGPU as for the Nature bench.....
....and Vince, EVEN at 5310MHz on 2k5, there is NO WAY to reach 115 marks on GT1....;)
I'll be back though BUT after the Cebit..... :(
Great result of aquamark!
next lap, 3d:D;)
That card was kinda sad, but congrats on the AM3 WR :)
Did you test how far the CPU went on 680i?
