Originally Posted by C.h.r.i.s
what do you mean by "vcore problems"?
Problems similar P5B DLX,too much vdrop...the mobo's power section isn't strong enough.Quote:
Originally Posted by tzitzos
EDIT= thanks to all :)
Hmm...thinking of trying an AB9 QuadGT myself...looks pretty strong at low clocks, wonder how it is under extreme cold.
? U can always do vdrop mod, if dropping is stopping u to achieve some cpu speeds.Quote:
you can make the pencil mod for the vdrop.then i think you will not have any kind of problem ;)
With all the mods on we can't benching over 5450mhz like P5B DLX...:(Quote:
Originally Posted by Misko82
amazing work bro :toast:
so take the "big 8" :fact: :woot:
Incredible almost sub 9 seconds :slobber:
beter , it s only 0.001 sec for the sub 9 :banana:
OMG, what I did't see...
Congratz boy, amazing score... :slobber:
'Mazza che roba... :D
Bye! :)
but for thats not guilty vdoop, simply p5b-variations has lower quality power section comparing to best 975 mobos.Quote:
once again magical clock for Spi 1M :toast:
very nice result guy's
I know how you must feel not breaking the 9sec (well, I think I know) I needed 0.016 more to achive sub 10 :slapass:
Keep it up, and break the 9sec :toast:
cogratulations man..
was real fast!
It compliments, those 9 buckets are one wonder;) :toast:
mmm... also we have had serious problems with the commando, we have stopped ourselves to 5300Mhz.....:nono:
460 3-3-3-1 at what voltage?? :toast:
voltage was 2.7 but there were no problem at all with just 2.6Quote:
Originally Posted by jozzy
Can you use SetFSB to P5W64? :confused:
If use to my P5W64, SM BUS Error happens.:(
Inform available method :D
Open clockgen befor and after use setfsb.Quote:
Originally Posted by OC_Windforce
Originally Posted by roro
Thank you. :D
:bounces:Quote:
Originally Posted by PallMall
Is it?Quote:
Installing your OS on a higher clocked system (let's say 5.3 - 5.4GHz) is a real help.
Little tip I picked up from OPB: make a .BAT file of all your reg tweaks so you can add them to your reg everytime you start benching again. Your regestry should be a lot cleaner.
grandi! - great! :woot:
Incredible clocks !
Happy to see the best spi time ever.
Also, I'm very impressed by your spi time at 3600MHz. sub 13.8s is very good !
no need to prove that and not "others" For OPB's fake, ask to Gautam.. OPB=Coolaler=1M cheats and ???Quote:
Originally Posted by NiCKE^
Chris, can you give us your optimizations about the 36GP (13.781 at 3603) ? :)
it's a fantastic score ^^
